Browse Forums General Discussion Re: Drop edge beam - need help with the plan 4Oct 15, 2015 9:00 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop edge beam - need help with the plan 7Nov 27, 2015 8:48 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop edge beam - need help with the plan 9Nov 27, 2015 10:22 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop edge beam - need help with the plan 14Dec 08, 2015 8:27 am ![]() ![]() If you Study the steps properly the site plan doesn't match the elevation with the number of steps? Also the middle landing lines up with the wall? My point is if its done in 3D you can consider alternate options, views and they will be accurate! I always make stairs a major feature, its what brings you into the house and transcending levels. Sorry I don't do or comment on landscaping others may "If you Study the steps properly the site plan doesn't match the elevation with the number of steps? Also the middle landing lines up with the wall?" - Not sure what you mean here. Could you explain the two things a bit here? I asked the builder. They don't provide 3D drawing. http://s1166.photobucket.com/user/struc ... sort=3&o=0 Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop edge beam - need help with the plan 15Dec 08, 2015 8:32 am ![]() ![]() ![]() If you Study the steps properly the site plan doesn't match the elevation with the number of steps? Also the middle landing lines up with the wall? My point is if its done in 3D you can consider alternate options, views and they will be accurate! I always make stairs a major feature, its what brings you into the house and transcending levels. Sorry I don't do or comment on landscaping others may "If you Study the steps properly the site plan doesn't match the elevation with the number of steps? Also the middle landing lines up with the wall?" - Not sure what you mean here. Could you explain the two things a bit here? I asked the builder. They don't provide 3D drawing. http://s1166.photobucket.com/user/struc ... sort=3&o=0 Thanks a lot StructuralBIMGuy. Where it says in the site plan that it's 3 steps? Re: Drop edge beam - need help with the plan 16Dec 08, 2015 8:45 am ![]() Thanks a lot StructuralBIMGuy. Where it says in the site plan that it's 3 steps? http://s1166.photobucket.com/user/struc ... sort=3&o=0 Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop edge beam - need help with the plan 17Dec 08, 2015 8:59 am ![]() ![]() Thanks a lot StructuralBIMGuy. Where it says in the site plan that it's 3 steps? http://s1166.photobucket.com/user/struc ... sort=3&o=0 Thanks again. Really appreciate your effort ![]() Re: Drop edge beam - need help with the plan 18Dec 08, 2015 9:18 am ![]() ![]() ![]() Thanks a lot StructuralBIMGuy. Where it says in the site plan that it's 3 steps? http://s1166.photobucket.com/user/struc ... sort=3&o=0 Thanks again. Really appreciate your effort ![]() No Problems..you really must insist on your drawings and documentations being correctly coordinated and your Designer/Engineer/Builder also must explain these options , processes, benefits, cost implications, etc,etc so you are able to understand them and make informed decisions Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 13558 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 28053 ![]() I would like to build our new house with the rear section approx 1 metre out of the ground, I don't particularly like to go bearers and joists so concrete slab all the way… 0 4069 |
