Browse Forums Paving & Concreting Re: Suggestions for paving and drainage? 2Nov 29, 2015 5:48 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Suggestions for paving and drainage? 3Nov 29, 2015 6:06 pm ![]() One option is one of these drains: http://www.everhard.com.au/outside_the_ ... mer-grate/ Yep was looking at these which require a fall. If I installed a channel drain it would need to be dead level. I am looking at Aco drains http://www.acodrain.com.au/klassikdrain/k100/index.htm they are presloped so water doesn't sit in the channel. My concern is if I run the fall back towards the house would this be a problem? Obviously if the area floods water would build up near the foundation. Re: Suggestions for paving and drainage? 4Nov 29, 2015 8:24 pm I would never slope the paving towards the house. . . . why risk damaging the foundation of your house. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Suggestions for paving and drainage? 5Nov 29, 2015 8:34 pm I've installed over 30 metres of Everhard, and it works well. Another option is RELN, and they offer different sizes for various flow levels. http://www.reln.com.au.ds015.imagri.com.au/Products/Surface_Water_Drainage Reln seems to offer more accessories, e.g. pits etc. Prices for each differ depending on the "big" store you choose. Setting up little pads underneath using bags of concrete can help. Just double check the fall is correct before it sets. Re: Suggestions for paving and drainage? 7Dec 01, 2015 12:36 pm ![]() I've installed over 30 metres of Everhard, and it works well. Another option is RELN, and they offer different sizes for various flow levels. http://www.reln.com.au.ds015.imagri.com.au/Products/Surface_Water_Drainage Reln seems to offer more accessories, e.g. pits etc. Prices for each differ depending on the "big" store you choose. Setting up little pads underneath using bags of concrete can help. Just double check the fall is correct before it sets. Thanks, I've looked at both products but the installation recommends the channel to be installed with a fall of 30cm for every 20meters. Hence why I have chosen the pre sloped channel drains. My concern is risking damage to my foundation Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 7508 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 16196 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3524 |
