Browse Forums Paving & Concreting Re: Steep, slippery driveway........ looking for suggestions 6Nov 29, 2015 11:00 am Hi GillyM Paints and surface finishes can be problematic over time You might want to consider surface roughening or grooves ground in but it appears your concrete has an oxide/colour finish surface? If it is not colour through, then surface roughening may look awkward/after thought. BTW For safety, Ramps/driveways should have a gradual slope of less than 1:8-1:10 Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steep, slippery driveway........ looking for suggestions 7Nov 29, 2015 11:11 am You want to make sure that the driveway was built according to the council guidelines/and or your final plans and not what was easiest or cheapest for the concretor or builder. Most councils will allow you a bit of latitude in this area as well to compensate for sloping land. Stewie Re: Steep, slippery driveway........ looking for suggestions 8Nov 29, 2015 11:30 am StructuralBIMGuy Hi GillyM Paints and surface finishes can be problematic over time You might want to consider surface roughening or grooves ground in but it appears your concrete has an oxide/colour finish surface? If it is not colour through, then surface roughening may look awkward/after thought. BTW For safety, Ramps/driveways should have a gradual slope of less than 1:8-1:10 Yes, it has the black coloured through. A more gradual slope would have been good, but it is what it is, so now I just need to work with what we've got! Re: Steep, slippery driveway........ looking for suggestions 9Nov 29, 2015 11:31 am Stewie D You want to make sure that the driveway was built according to the council guidelines/and or your final plans and not what was easiest or cheapest for the concretor or builder. Most councils will allow you a bit of latitude in this area as well to compensate for sloping land. Stewie It's all been approved, so I'm guessing that it is all ok with council. no doubt it was the easiest/cheapest for the concretor and builder though! Re: Steep, slippery driveway........ looking for suggestions 10Nov 29, 2015 11:43 am Yes I would say you are guessing, did they supply Council Drawing/Engineering details?...check with the Council Building Dept as already mentioned by StewieD! Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steep, slippery driveway........ looking for suggestions 11Nov 29, 2015 12:13 pm I know the Engineer was here during the process, as he had to approve parts of the driveway, and they couldn't complete it without his tick of approval. Which he did give. Masterton Overture 17/12/14 - Handover ...... we got the keys !! blog - http://www.mcnamaraadventure.blogspot.com Re: Steep, slippery driveway........ looking for suggestions 12Nov 29, 2015 1:20 pm I'd suggest that the engineer just made sure the driveway was completed as per the original plans and as per his/her structural drawings. You can usually download the requisite guideline drawings from your council website. An example from our local council... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Stewie Re: Steep, slippery driveway........ looking for suggestions 13Mar 14, 2017 7:16 pm Received a msg abut this from Venessa, but HomeOne says I can't respond as the user is no longer registered, so hopefully Venessa will read this, and I will respond here! Hi Venessa...... yes, indeed we did find a solution! We found a local concretor who ground the driveway back to concrete (ie: got rid of the sealant that was causing it to be slippery) and sprayed it with a coarse cement mix in a brick type pattern. The pattern helps give it a bit more grip as there are "edges" to the pattern which gives more grip. Nobody has slipped on it since! It cost about $3,000 (ouch!) but it really had to be done. Hope this helps! Cheers, Gilly. Masterton Overture 17/12/14 - Handover ...... we got the keys !! blog - http://www.mcnamaraadventure.blogspot.com Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 358064 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7375 Suggestions please for acrylic rendering Color to match austral brick urban one pepper. Pic for reference. Thanks 0 5132 |
