Looking good! .............
Browse Forums Pools & Spas Re: Concrete Swimming Pool - Owner Builder in South Australi 25Jun 30, 2016 9:26 am Hi any finished progress pictures and advise? Re: Concrete Swimming Pool - Owner Builder in South Australi 26Jul 15, 2016 9:43 pm I have been busy with the build and have not had time to post any extra photos - Sorry !
I will upload some more photos soon. I do have a couple on hand to upload now. See Below.. All the pipes that run to the pump station. There is: 1 - Water out (Skimmer Box) 2 - Filtered water in (Return) 3 - Spa Jets in - Airated in (Return) 4 - Solar heating out 5 - Solar heating in (Return) 6 - Blower Jets -in (Fan air in (In Seat Spa Blower Jets) Re: Concrete Swimming Pool - Owner Builder in South Australi 27Jul 15, 2016 9:47 pm Top View of pool with shoring of the pool wall. I had to fill this gap in as I excavated the hole too large. Should have been only 3.5m wide but I made it 4m. I had to shore it up and then once the concrete pour was complete I had to fill it in with clean clean dirt. I then flooded it with the garden hose to make it compact like quick sand and then do it over and over again till it was fully filled.
You can see the gap below: Re: Concrete Swimming Pool - Owner Builder in South Australi 31Jul 22, 2016 9:03 pm I needed a strip footing to support the pergola posts and future glass pool fence, so I hired an excavator from the local hire mob. The engineer drawings specified a footing that was 300mm wide and 400mm deep with 4 x Reo Rods of N16 in size. Re: Concrete Swimming Pool - Owner Builder in South Australi 38Sep 21, 2016 9:39 pm Ordered 2.4Cubic meters of Concrete from a local premix concrete company. Had 3 wheel barrows working for 2 hours and here is the finished product. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Amazingly, the left over for this job was less than half a bucket of concrete. I did the calculations but must admit it was more arse than class. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We have a Jakaranda tree in the back yard and it is flowing a purple rain. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lot of work in a short amount of time but all ended well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now I can let it cure for a while under plastic. I need to now order the fence and this can take a while so the concrete strip footing will be more than cured by the time I arrange the fence. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4694 Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO… 3 47712 |
