Browse Forums Building A New House Re: Front Setback calculation (rescode 409) clarification 14Apr 23, 2016 4:12 pm Anyone had to apply for minimum front setback through monash council? Re: Front Setback calculation (rescode 409) clarification 15Apr 23, 2016 4:33 pm sian.wickham Anyone had to apply for minimum front setback through monash council? Not from Monash, but we had to apply for the same from Wyndham and we got ours approved in 6 weeks time. Re: Front Setback calculation (rescode 409) clarification 16Apr 23, 2016 4:35 pm Thanks ak1983, what setback did you want? We have a minimum of 7.6 through monash and we want 4.5 from front porch. On one side they are 4 metres and the other they are 7. Re: Front Setback calculation (rescode 409) clarification 17Apr 23, 2016 5:25 pm sian.wickham Thanks ak1983, what setback did you want? We have a minimum of 7.6 through monash and we want 4.5 from front porch. On one side they are 4 metres and the other they are 7. We were required to be at 5.2m (as the average of the either side property 4m and 6.4m respectively). And we asked for 4.2m which got approved. Also, not sure why you are considering it from front porch as far as I know the setback is considered from the front habitable wall and not porch as long as it is not more than 3m in height(which would be unlikely) unless there is something specific about your build/council. Re: Front Setback calculation (rescode 409) clarification 18Apr 23, 2016 5:34 pm Yes, it is considered from the front of house so at house we want 5.5m. We are going with porter Davis and they will do it for us we are just concerned that they will miss including done critical things. Re: Front Setback calculation (rescode 409) clarification 20May 22, 2016 9:58 pm Anyone have any idea of how long the front setback dispensation usually takes?? Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15767 While i was across this behavior's pre appointing my (the builders) surveyor, I did tell the builder i was aware what they were doing and while i disagreed with it, they… 13 14589 I am not based in Victoria however i had a quick look into your question to understand what you were asking. The way I read the regulations, overshadowing relates to the… 1 2233 |
