Browse Forums Building A New House Re: Henley Carmelle Lux Q2 - Taps on the block 290Oct 20, 2015 3:56 pm cool thanks for the tip tender appointment 2moro trying to write down all the things i want to ask them Re: Henley Carmelle Lux Q2 - Taps on the block 291Oct 23, 2015 8:20 am snyde Ooops, my bad, I meant from Admin / contracts to construction site handover.. the build's about to start. Yep, we'll be doing the flooring ourselves after handover. Re: Henley Carmelle Lux Q2 - Taps on the block 292Oct 23, 2015 8:27 am They can do the architraves, but we've just requested the skirting boards stay off so we can install the skirting boards over the flooring, that way we don't have to put quads down anywhere. Re: Henley Carmelle Lux Q2 - Taps on the block 293Oct 23, 2015 8:36 am Bit of an update We seen our basins installed on a friends recent build, seeing them in person looked horrid. We've quickly got onto our admin and updated our ensuite and powder room basin and taps to these: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thankfully we've had a great admin who's helped us with the change. Our block's been measured, and has also been assessed by the new SS and should start next week! Re: Henley Carmelle Lux Q2 - Taps on the block 294Oct 23, 2015 12:38 pm snyde They can do the architraves, but we've just requested the skirting boards stay off so we can install the skirting boards over the flooring, that way we don't have to put quads down anywhere. Re: Henley Carmelle Lux Q2 - Taps on the block 295Oct 23, 2015 3:18 pm we have same tapware and basin in powder room, it looks just so cool. good decision to upgrade Re: Henley Carmelle Lux Q2 - Taps on the block 296Oct 23, 2015 5:04 pm What basin and tap is that Snyde? Love it! & what did you have previously? Re: Henley Carmelle Lux Q2 - Taps on the block 297Oct 23, 2015 6:05 pm Thanks mirz. It's the Gem Inset basin with Rush Wall Mixer. We had the Leda Vasque above counter basins originally selected with vivid mixer. Re: Henley Carmelle Lux Q2 - Taps on the block 298Oct 23, 2015 11:46 pm May I ask how much this upgrade was for? Re: Henley Carmelle Lux Q2 - Taps on the block 299Oct 24, 2015 10:03 am Basins were $260 each in lieu of the Veda Lasque ones (they were approx $60 each I think?) The taps are $165 each Re: Henley Carmelle Lux Q2 - Taps on the block 300Nov 05, 2015 5:47 pm Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 12984 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4939 That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel 2 8254 |
