Browse Forums Paving & Concreting Re: Sewerage Access in way of Footpath 2Oct 13, 2015 1:32 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Sewerage Access in way of Footpath 3Oct 13, 2015 3:09 pm bashworth What you have in that picture is a basic (cheap) IO cover and Frame. The basic thing that is required is a strong easy to remove cover over the inspection shaft. A couple of Options are A. Instead of using the precast frame cast a new frame for the existing cover in the path concrete. B. Cast a Cast iron cover and frame in the concrete path. Although obvious it will be much smaller( see Flanged I.O. cover and frame • Type 1 at this link for an example http://www.ri-industries.com.au/commerc ... -openings/) Hi Brian, Thank you so much for your advice. I will have a look at both options, but that pre-cast cover and frame look like a much better option. I will try and find some locally (Vic). P.S Thank you for your PCI guide. It really helped us out during our PCI. Re: Sewerage Access in way of Footpath 5Oct 15, 2015 8:13 am Crazyk Thanks CrazyK. Will look into that too. Re: Sewerage Access in way of Footpath 6Oct 15, 2015 8:22 am joea bashworth What you have in that picture is a basic (cheap) IO cover and Frame. The basic thing that is required is a strong easy to remove cover over the inspection shaft. A couple of Options are A. Instead of using the precast frame cast a new frame for the existing cover in the path concrete. B. Cast a Cast iron cover and frame in the concrete path. Although obvious it will be much smaller( see Flanged I.O. cover and frame • Type 1 at this link for an example http://www.ri-industries.com.au/commerc ... -openings/) Hi Brian, Thank you so much for your advice. I will have a look at both options, but that pre-cast cover and frame look like a much better option. I will try and find some locally (Vic). P.S Thank you for your PCI guide. It really helped us out during our PCI. Hi Brian, I measured the current riser and it's 130 mm in diameter. Can I get away with the 150 mm IO or do I need to go with the 230 mm for more access? Thank you. http://i1371.photobucket.com/albums/ag297/joeassi/IMG_3430_zpsp7fs10mb.jpg Re: Sewerage Access in way of Footpath 7Oct 18, 2015 8:24 pm I have opened plenty of these when I was still working in the sewage business and wouldn't be too upset with the 150mm. Just don't screw that plastic cap on too hard. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20166 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9070 |
