Browse Forums Lighting + Lighting Design Re: Ask a lighting design engineer - general Q&A 2Oct 03, 2015 5:39 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Ask a lighting design engineer - general Q&A 4Oct 03, 2015 10:42 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Ask a lighting design engineer - general Q&A 6Oct 04, 2015 11:38 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Ask a lighting design engineer - general Q&A 13Oct 05, 2015 9:21 pm 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Ask a lighting design engineer - general Q&A 16Oct 08, 2015 8:02 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Ask a lighting design engineer - general Q&A 18Oct 09, 2015 10:33 am Thanks for your advice so far on this forum 1960sModernistHome. I have a quick question. I have ordered some domus down lights from your suggestions. I am installing in a new build. What is your opinion on using heat shields for the insulation? Or should I cut the insulation out around and protrude the downlight through? Re: Ask a lighting design engineer - general Q&A 19Oct 09, 2015 10:50 am This is probably not that helpful sorry, but my best advice is to follow the manufacturer's instructions (should be inside the Domus box when you open it up). The instructions should tell you how closely you can install the insulation, and whether a shroud is acceptable. In practice, LED downlights do not get anywhere near as hot as halogen downlights, so they are not a fire risk in that sense. But if you cover them with insulation it affects the heat disspation of the luminaire. The main issue with shrouding that I can see is that it may restrict heat disspation from the LED heat sink on the back of the downlight, which in turn may affect performance and possibly warranty or premature failures. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 You should check your detail drawings, it may show downpipe within brick pier. 14 14295 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15521 Ardo That is so funny! I wonder how many people know who Larry Haun is these days. I have a couple of young guys we call Mo 1 & Mo 2 who run a crew of 6 boys and… 9 15646 |
