Browse Forums Building A New House Re: Serpentine Build - with Cachet Homes 42Sep 15, 2015 3:41 pm Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Serpentine Build - with Cachet Homes 43Sep 16, 2015 5:38 pm Oh my gosh I love your plan! So looking forward to seeing how it all goes with your build Serpentine Build - with Cachet Homes 44Sep 23, 2015 4:11 pm Well brickies will be done by end of today apparently ! Roof starts next week Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Living looking out to alfresco - steel beams put in place yesterday for raked ceiling Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking out opposite direction - exit out of winter room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Serpentine Build - with Cachet Homes 45Sep 23, 2015 5:14 pm BTW your place is looking great, moving very quickly.
Re: Serpentine Build - with Cachet Homes 46Sep 29, 2015 10:07 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Soo dilemma , we were marking out chasing for the electrics Sunday and the steel beams are a bit of a problem . Picture is our recessed wall for tv and cabinet - ideas on how to chase for data and electrics ? Don't think we can drill through the steel I beam overhead ? It's in the brick work above the lighter strip . The beams also sit above two sliders going outdoors which we've been unable to have outdoor switches on the wall next to doors now bit annoying ! Re: Serpentine Build - with Cachet Homes 47Sep 29, 2015 10:49 am We had a similar issue with external switches and the beam above our sliding door. The electrician just came at it from a different direction. With the tv recess they may chase it on the other side of the wall inside the master suite. That wall appears to be double brick so the lintel may only be for that front course and not the second course that faces your master. Are you doing your own chasing? Re: Serpentine Build - with Cachet Homes 48Sep 30, 2015 11:28 pm Hubby is an electrician so we are doing our own wiring - someone doing the chasing for us our external switches we just moved to side wall as was just too much of a pain to go around the beams ! Had a site meeting this morning and ss reckons there is a gap to the left we can go down and come in from the side . A bit of a disappointment today though , as we were marking for chasing I couldn't help noticing our ensuite doorway wasn't quite right . Turns out when we made our ensuite bigger whoever was changing the plan decided to move the position of the doorway . The way it was supposed to work was doorway was in line with our floor to ceiling window at other end of the room which we plan on having an outdoor feature to look out to . OCD in massive overdrive as toilet wall is now not in line with doorway pic attached . There is supposed to be a void to the right as they will put framework in for a recessed sliding door .. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm actually pretty devo about it but trying to move on from what I can't change now roof also started today . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also met with plumber to confirm we were installing an atu unit as seems slight communication fail at cachet and they still had us down for a septic . they also forgot to get plumber to put in pipe work for our storm water to tank :/ so here's hoping that doesn't cause too many dramas ! Re: Serpentine Build - with Cachet Homes 49Sep 30, 2015 11:50 pm To overcome the OCD, you could frame up both sides and put in a conventional hinged door that lines up with window. (which is the less of 2 evils in your OCD world hinge or off centre? ) At this rate your place will be finished before ours. Which ATU did you end up going with? Re: Serpentine Build - with Cachet Homes 50Oct 06, 2015 9:55 pm They are moving so quickly, can't believe how fast it is all coming together. Looks great Re: Serpentine Build - with Cachet Homes 52Oct 12, 2015 10:43 am Wow your roof will be finished in no time, love the pics! Re: Serpentine Build - with Cachet Homes 53Oct 21, 2015 3:25 pm So looking around at house today and noticed a few things not quite right , from the start we provided photographs of what we liked / wanted and asked builder to incorporate in our build . Example we had a very specific facade in mind and looking at it now ... It's very different indeed feeling pretty let down and disappointed atm m Re: Serpentine Build - with Cachet Homes 54Oct 21, 2015 4:09 pm No good K! Did they not give you a drawing of how the façade would look before commencing works? Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Serpentine Build - with Cachet Homes 55Oct 23, 2015 4:09 pm We had supplied drawings already done by another builder ( family who we originally were going to build through but we would have had to wait too long to go through him ) and didn't realise they had changed it when we signed we also had raked ceilings in our theatre and they've put struts across the top so there will be a flat strip along the raked part . I'm definitely not having that! They extended a bulkhead in the kitchen so it turned out the whole kitchen ceiling was lowered but that's an easy fix so feeling better about that part . Just hate when we supplied ready down drawings and Pinterest photos and they change things without mentioning them and it's an obvious price cut for them I guess we just assumed that if they were changing anything they would let us know but rookie mistake I guess!
Re: Serpentine Build - with Cachet Homes 56Oct 23, 2015 4:12 pm Will be hard to change study ceiling now as the wood beam they used is a pine ceiling beam so can't really expose it now . They had more than enough of the good timber beams they could have put in there - they even used a good beam in the ceiling where it's all covered up ? Just doesn't make sense to me . Re: Serpentine Build - with Cachet Homes 58Oct 23, 2015 6:18 pm Have you checked what they are building is what's is on your signed off plans? Re: Serpentine Build - with Cachet Homes 59Oct 26, 2015 12:38 pm Yep signed plans def don't show what they are doing now was supposed to be raked . Roof carpenters are back today and are saying not sure how it could be changed now . Will be pretty upset if they can't fix it ! Re: Serpentine Build - with Cachet Homes 60Oct 26, 2015 12:49 pm That isn't really good enough! They need to take the whole roof off and start again if it isn't to plans surely?? Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17616 3 48399 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74715 |
