Browse Forums Kitchen Corner Re: Benchtop colour consistancy 6Aug 31, 2015 2:15 pm mike100jobstodo But it’s always best to find out whether your cabinet maker has cut out pieces of the actual benchtop that he can show you as a sample. This will help you visualise what your benchtop colour will look like when it’s done. Not really. Especially if its man made stones like CaesarStone. Colour can differ slightly from batch to batch. Also cabinet makers and kitchen companies out source the stone. It is most often done by a stone mason! Your best of actually going out to a stone mason and looking at there large format samples! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Benchtop colour consistancy 7Aug 31, 2015 4:01 pm CuttingEdgeKitchens mike100jobstodo But it’s always best to find out whether your cabinet maker has cut out pieces of the actual benchtop that he can show you as a sample. This will help you visualise what your benchtop colour will look like when it’s done. Not really. Especially if its man made stones like CaesarStone. Colour can differ slightly from batch to batch. Also cabinet makers and kitchen companies out source the stone. It is most often done by a stone mason! Your best of actually going out to a stone mason and looking at there large format samples! The stone was supplied by a distributor that then went to a stone mason, it was labelled correctly so the stone mason received the product in good faith from the distributor that it was correct. There is a certain tolerance allowed and I can understand that (the sample I collected from the distributor and the sample my cabinet maker had were slightly different and either would have been fine) The distributor did have large pieces available to see that were the same as my sample, but not at all representative of what they carried in stock. What I see the issue as, was that no one actually checked the incoming batch against the large or small samples they had on display. It actually goes right back to the manufacturer, if they had any standard procedures to check for colour consistency, they would have known that this batch was significantly different and should have sent new samples with the batch and informed the distributors. It's so demeaning when sales people tell you that 'this is the first time that something like this has ever happened' ??!! Do they think I was born yesterday?? Re: Benchtop colour consistancy 8Aug 31, 2015 5:53 pm Building15 [ It's so demeaning when sales people tell you that 'this is the first time that something like this has ever happened' ??!! Do they think I was born yesterday?? I can understand that, but. I might be the first time it has happened to that sales person. I have never had any come backs on stone colour. I think you were very unlucky. Normally the colour consistency is pretty good. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Benchtop colour consistancy 9Aug 31, 2015 8:16 pm CuttingEdgeKitchens Building15 [ It's so demeaning when sales people tell you that 'this is the first time that something like this has ever happened' ??!! Do they think I was born yesterday?? I can understand that, but. I might be the first time it has happened to that sales person. I have never had any come backs on stone colour. I think you were very unlucky. Normally the colour consistency is pretty good. Yes you are probably right.... Still, am feeling a bit jaded and let down, as is my cabinet maker It is not something I would be in a rush to recommend that is for sure And the lesson is, Buyer Beware!! Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12921 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7158 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 |
