Browse Forums Building A New House Re: I want YOU....to tell me if you'd add/change anything in 4Aug 27, 2015 9:34 am Thanks guys, appreciate the input. The drawing is labeled correctly I should have mentioned, the living room is actually a TV/media room for my wife and I and the rumpus is a kids play room. Aussiemark - were u suggesting to make the WIL shorter, maybe 500mm deep and not walk in and then bring the opposite laundry wall in 500mm to make an alcove in the garage opposite for shelving? Re: I want YOU....to tell me if you'd add/change anything in 5Aug 27, 2015 9:44 am Philip, yes exactly or make the room on the other side of the laundry bigger. The walk in piece serves no purpose is the storage is on one side only. Its wasteful and can be better utilised in either of the two rooms. If you are happy with living room side then make an alcove in the garage for shelving. Re: I want YOU....to tell me if you'd add/change anything in 7Aug 27, 2015 10:25 am The way the door opens in your Ensuite toilet, either make it opening the other way or a sliding door. Looking at it, swings to the toilet. Same as others WIL you can utilise that space better - whether garage or Living Just a thought to put in sliding glass door between entry and Family/meals so able to close it off, for heating or cooling. Personal preference though. And I would do all wardrobe doors sliding. Re: I want YOU....to tell me if you'd add/change anything in 8Aug 27, 2015 10:35 am Yeah I've told the builder to change the ensuite toilet door, that was just an oversight. I've always had sliding doors to robes but my builder suggested normal ones...when I think about all the times that some part of the robes is always hard to access regardless of where the doors are, I tend to see the benefit of normal doors. I guess if you had triple sliding doors to robes it would be better, but I think there is merit in normal doors, well see I guess Ilk definitely speak to the wife though about the WIL and adding a cavity door to hallway / family area. Thanks again. Re: I want YOU....to tell me if you'd add/change anything in 9Aug 29, 2015 10:58 am My 2 cents.. Think of which areas of the house you are going to spend most and enhance them.. To get more light and air in.. I would move the pantry away from the wall and have the kitchen facing the garden/sidewalk which can have nice flower/water feature to look into.. Also, I'd swap bed 2 and rumpus, and then add a sliding door to rumpus opening into outdoor area, so that family/meals/rumpus cluster would be a nice big open space.. Light and airy.. Then change the wall between family and the new rumpus to be a see-through wall or half-wall, so that when you get into the house from porch/entry it would feel nice and big from there as you can look into the garden behind the window in the new rumpus. Sent using Tapatalk mobile app Re: I want YOU....to tell me if you'd add/change anything in 10Aug 29, 2015 8:44 pm Philip_J Thanks guys, appreciate the input. The drawing is labeled correctly I should have mentioned, the living room is actually a TV/media room for my wife and I and the rumpus is a kids play room. Aussiemark - were u suggesting to make the WIL shorter, maybe 500mm deep and not walk in and then bring the opposite laundry wall in 500mm to make an alcove in the garage opposite for shelving? Definitely. I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36963 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110666 The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4273 |
