Browse Forums DIY, Home Maintenance & Repair Re: Re painting door frames 5Aug 26, 2015 2:27 pm Beazley77 Thanks YNOTDOY. Door frames aren't yellow as thy are new. When I say chips it's more like paint has been knocked off. I'm also looking to fill the lower door frame stay "holes" that are normally covered by the height of tiles but in a couple of doors we have the polished concrete. I've seen how to fix these with auto bog so it's a weekend DIY job and then maybe a whole frame repaint if the patch looks no good. Thankfully they are right down near the floor. I have used epoxy putty for similar repairs. Usually found in paint departments of hardware stores. Re: Re painting door frames 6Sep 09, 2015 10:32 am If you want your door frame colour to look consistent, re-paint the whole door frame. You have to first remove any surface rust or loose paint from your door frame with a wire brush. Then you need to remove any loose paint. After that, apply a good quality primer and paint to your door frames. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 9014 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10831 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 19043 |
