Browse Forums Kitchen Corner Re: Solid Timber Benchtops 3Aug 19, 2015 8:29 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Solid Timber Benchtops 7Aug 24, 2015 2:23 pm My Owner/Builder weatherboard house thread: https://forum.homeone.com.au/viewtopic.php?f=53&t=77475 Re: Solid Timber Benchtops 8Aug 24, 2015 3:22 pm how does the wood stand up to the moisture introduced by everyday use? Is it treated with aditional chemicals, or is it poly'd over? would wax be effective? Just curious, as Ive always considdered stone for longevity, but I prefer a nice hardwood. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Solid Timber Benchtops 9Aug 24, 2015 3:24 pm They waxed our vanities although part of the reason we went teak is because that is what was initially used in boat building. We have a solid Timber Jarrah worktop on our kitchen benches that are at least 15 years old and they stand up beautifully <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Solid Timber Benchtops 10Aug 25, 2015 10:02 am Yes, your solid timber benchtops will definitely be a selling point for your house next time. They will give your house charm and character. However, do keep in mind that you have to continuously maintain your timber benchtops so that they look as good as new by the time you decide to sell your house. Re: Solid Timber Benchtops 11Aug 27, 2015 8:01 am AKB I've done wood for my vanities and will do hardwood for our kitchen - photo of vanity below . Personal taste I guess ] Your bathroom looks great but there is more to it than just personal taste! Timber bench tops especially in kitchens require maintenance(sanding and refinishing) and need to be refinished every couple of years. Depending on the species of timber they can show dents and marks as well. Stone doesn't have any of these problems. For someone looking to buy a house this is a vey real consideration! Personally if I were building a house to sell in a few years time I would always use stone in the kitchen and bathrooms! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Solid Timber Benchtops 12Aug 30, 2015 6:06 pm We went for both, stone & timber Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15918 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8313 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6153 |
