Browse Forums Owner Builder Forum Re: New OB Project thread 2Dec 21, 2014 3:04 am Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: OB Project - "New vs Old" - Nedlands, WA 14Aug 20, 2015 2:16 pm Build thread: viewtopic.php?f=38&t=75302 Re: OB Project - "New vs Old" - Nedlands, WA 15Aug 20, 2015 10:02 pm gandn Does that price you have include anything or do you have to supply the rest also? Sand, cement, brick ties, lintels etc? Nope... it doesn't include anything. In fact the second storey is charged at $1.50 per brick. I've read here some of the OBs have managed to find much lower rates. Ive had no such luck. I also don't want to sacrifice accuracy as my doors and windows will be retrofit so walls and openings need to be accurate. Atleast the second floor is now timber. Re: OB Project - "New vs Old" - Nedlands, WA 16Aug 20, 2015 10:08 pm As my earthmover guy tells me Brickies build your house ...,.especially over here in the west where everything is double brick (kind of like a carpenter over east I would imagine). I'm an accountant and the prices Brickies started getting two years ago really increased. Builder were throwing in new cements mixers as incentives to try and get Brickies on board <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: OB Project - "New vs Old" - Nedlands WA 17Aug 20, 2015 11:37 pm Demolition complete!! Not much left of the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Next step was to stabilise the soil under the original footings. The original house is set on limestone footings which are in reasonable condition, however as we intend to drop the floor level by about 1.4m into the addition the new slab will be well below the existing footings. Step one is to stabilise the soil with chemical grout injection to a depth of about 1m. We will later reinforce this with a cavity fill wall also. The grout takes 3 days to start to harden and can be shaved into your desired shape in about 5-7 days. It reaches max strength in about 1 month. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The above picture shows injection points set approx 200mm apart. Re: OB Project - "New vs Old" - Nedlands, WA 18Aug 21, 2015 6:18 pm Looking good kasra - It's been a while since I have been in the OB forum, but glad I popped back today. I'll be following your thread for sure. Good decision you took those Tree roots out from under the slab otherwise over time it would have just rotted away and that's not good for under a concrete slab. Also think you have made a smart move removing the old Garage. From the photos it didn't look original anyway so not too much damage done Keep the pics and updates coming. https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: OB Project - "New vs Old" - Nedlands, WA 19Aug 21, 2015 11:25 pm docker_rob From the photos it didn't look original anyway so not too much damage done Good pick up!! Yes, I'm glad we knocked it over. Also access would have been a nightmare. Re: OB Project - "New vs Old" - Nedlands, WA 20Aug 22, 2015 12:17 am Soak wells installed. Based on our roof area we require 2 x 1500x1500 soak wells. To be extra safe we have decided to place an extra 1500x1500 in the front also. This will give us an additional 50% safety margin over BCA. Most likely overkill. Now comes the interesting part... We are planning on having a 3 quote policy for all trades and this example demonstrates why its very important to take the time to get multiple quotes. Here were the results: 1. Plumber who I had used previously for mainly maintenance - $6900!!! for 3x 1500x1500 installed 2. Earthwork/landscape guys currently working onsite - $5000 for 3x 1500x1500 installed 3. Drainage guy who was referred to me by a friend. - $1500 for 2x 1500x1500 installed Job done!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4830 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 28045 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19914 |
