Browse Forums Bathrooms and Laundry Re: Brand selection 8Aug 17, 2015 1:25 am AussieMark I am not sure how many taps you are looking to get but I have grohe throughout the entire house and depending on which line you select you will motor through 5k very fast. Minta Kitchen taps are 650 plus. Basin taps I have linear and they from memory were over 500 each but you can get essence which look nice for around 300. The shower mixers are also quite pricey. Caroma Opal 2 toilets are around 950, I ended up going villeroy and boch as it was not a lot more relatively speaking. Basins I went with V&B to keep it all the same. If you are owner building I would go to Harvey Norman commercial and list down everything that you want and ask them to quote. If you are in Perth you could also go to Parkwood plumbing and see all of the brands laid out and you can ask questions. They may be able to put a package together. Remember you will also need shower rails and roses plus all the bathroom accessories and they can mount very very quickly. Yes 5k is indicative but I can see we will go over that. We've decided on an Abbey sink and mixed supplied through the kitchen builder so it's just powder room, ensuite and main bath. The laundry is also sorted. We aren't owner building but using a local Master builder. We don't mind if it's more but I want to make sure the spending is in the right spot. What about toilets? Are Roca decent? I see they might not be as popular in Australia as Europe.. I heard Caroma toilets aren't as good as they used to be?.. Re: Brand selection 9Aug 17, 2015 1:26 am Building4my3tots Thanks for your replies, yes we are (to be deducted from PC). Our builder prefers to use the local Reece as their supplier but we can get if from or ask for them to get it from wherever we want really. Re: Brand selection 10Aug 17, 2015 6:42 pm I would look at upgrade costs for the basins And wc. For my house I have 6 toilets And 7 basins. To upgrade from builders standard to v&b was about 3k. Re: Brand selection 11Aug 17, 2015 11:53 pm AussieMark I would look at upgrade costs for the basins And wc. For my house I have 6 toilets And 7 basins. To upgrade from builders standard to v&b was about 3k. Thanks. Well as we're doing a custom build there is nothing specified, we just need to choose them ourselves and have an allowance of 5,500k but may go over that. We do want better than the standards builders brand but don't want to be ridiculous. Six toilets! That's a lot! Our house is 236sqm internally with two toilets only we have two basins in the ensuite. One in the main and the powder room. So if we decide upon more expensive items it's not a killer. Our floor grates are going to be about $1200, 600 each as we are having 6x6 tiles on tbe floor and so don't want to have to cut them for a small waste. Plus it suits the showers. We don't want the ones with plastic underneath as they don't finish as well with the tile and the all stainless are expensive. Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 6223 Pay again? No retribution? Your glass has a specific performance get this app and see how much your windows are leaking, then challenge the supplier. 3 5289 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6891 |
