Browse Forums Building A New House Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 3Dec 19, 2008 5:43 pm Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 11Dec 22, 2008 12:19 pm jamestheoz Hope this doesn't sound too complicated. Cheers, jamestheoz Is it just me or did everyone else get lost after the: "We are doing the following pre-wiring in our home for TV / Foxtel. " bit? Could you draw a diagram? Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 12Dec 22, 2008 12:58 pm Sorry Jamestheoz.. even I lost you after a while
I just got a quote from the person for the installation.. this is what he had to say : 1. Supply and install 1 x Foxtel & IQ prewire to roof area for connection at a later date. 2. Supply and install 1 x Foxtel back feed lead to roof for connection onto television coaxial. 3. Supply and install 1 x Back feed lead for satellite set top box to roof area for connection into television coaxial. 4. Supply and install RF Modulator for Foxtel/IQ box. 5. Supply and install fly leads/scart leads as required Is this ok or should I be looking at something more ? (To tell u the trust some of this also goes over my head !! Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 14Dec 22, 2008 1:49 pm Attached is a basic concept drawing of the TV cabling plan.
Excluded is Cat 5 cabling which goes into the same wallplate as the TV cable All cable is Quad Shield cable. A 300m roll should cost about $150, maybe cheaper on ebay. Don't bother at retail electronics stores as they charge per metre and worse than a wounded bull! Try Middy's or Leckys, etc. and ask for trade pricing! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 15Dec 22, 2008 3:58 pm nonie hi Hoffies This is awesome .. 6 yrs .. wow ! Can you tell me the name of the device and from where you got it installed The brand is Smart Connect. It's a 2.4ghz audio/video sender receiver. Got it from Tandy or **** Smith. You just plug it into your TV's. Re: Foxtel..Changing channels for $1300 !!!Matt ..Rod.Help!! 16Apr 01, 2010 4:13 pm jamestheoz Both images got 404 Not Found Error.. Did you removed the pictures?? If yes then please post it again here as I would like to have a look at it to have a better idea of it. I asked this question of one of the forum's resident cabinet makers who may/may not wish to identify himself to answer other questions if he sees this, but the rersponse… 3 7766 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11977 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5563 |
