Browse Forums Kitchen Corner Re: Bench height 4Jul 30, 2015 7:33 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Bench height 8Aug 11, 2015 7:21 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Bench height 16Aug 13, 2015 8:29 am When you decide on a height make sure you take into account the flooring. For example our builder installed the bench tops 920mm above slab height but by the time we lay the tiles it will be more like 900mm. Re: Bench height 17Aug 13, 2015 9:05 am Yes we have hardwood floor so that will be a factor, it should end up just right. Re: Bench height 18Apr 25, 2016 9:41 am I've a question about bench height. For a 900mm bench height should we add on the floor which will be installed second (16mm, I think) and are people referring to a finished height of 900mm in which case we need to take bench top into account also? Thanks Re: Bench height 19Apr 25, 2016 8:44 pm lazandjohn I've a question about bench height. For a 900mm bench height should we add on the floor which will be installed second (16mm, I think) and are people referring to a finished height of 900mm in which case we need to take bench top into account also? Thanks Everyone is talking finished height!! If your putting your floor down after the kitchen you need to allow extra height on the kickboard. So in your case bench height before the floor needs to be 916mm for a 900mm finished height. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11682 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31263 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3796 |
