Browse Forums General Discussion Re: Buying land, worrying about gas connectivity 2Aug 10, 2015 7:56 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Buying land, worrying about gas connectivity 4Aug 10, 2015 9:18 pm bashworth Contact your local gas supplier, they should be able to tell you. Matt1 Call Jemena (although their records aren't always accurate, ours weren't for an estate in Kellyville, just up the road from you). I'd be very surprised if they didn't put gas in. Thank you guys, will call them. But am I right that for each house connection is actually achieved by drilling to main pipe? And never there could be pipes with valves protruding from the earth on the new lots? Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Buying land, worrying about gas connectivity 5Aug 10, 2015 9:48 pm They didn't in our estate. I'm guessing is because they do a straight run from the kerb to where the meter will be and they don't know that until you build. Re: Buying land, worrying about gas connectivity 6Aug 10, 2015 10:07 pm Matt1 They didn't in our estate. I'm guessing is because they do a straight run from the kerb to where the meter will be and they don't know that until you build. thanks Building Casaview Denison 30 https://fortdenison.wordpress.com/about Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6640 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20369 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3778 |
