Browse Forums Eco Living Re: Rainwater collection - questions?? 21Aug 04, 2015 1:55 pm Hey thanks Boosta, will having a good read now. I found the super diverter to be an excellent idea and think could use it on the dead side of the house but not on the garden side (just for looks). The idea of two tanks was to have the smaller tank as the "clean" tank (need eliminated with all supadiverters but I won't have this). Another question for the low restriction inlet the inlet needs to optioned on the tank when purchasing? Re: Rainwater collection - questions?? 22Aug 04, 2015 4:04 pm the low restriction inlet needs to be optioned hence the reason why I went with a colourbond steel tank (suspect you can't do with Poly as most will have a drain valve and outlet for pump but all not situated at 100mm from base as recommended) as it was manufactured to my specs. The two tanks is a preference, I just don't have the "space". FYI, the "horizontal" pipes for the supadiverta for mine starts from 25mm (furthest from tank) to 40mm before merging into 50mm for the 50mm inlet. http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Rainwater collection - questions?? 23Aug 04, 2015 8:35 pm Re: Rainwater collection - questions?? 24Aug 05, 2015 9:30 am If the image was provided by Dennis, I will go with it. http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Rainwater collection - questions?? 25Aug 05, 2015 3:13 pm That would be a no brainer, but no I drew the diagram from all the info available in home one from various threads heavily supported by H2O! Re: Rainwater collection - questions?? 26Aug 06, 2015 4:05 pm I got excited thought Dennis had responded, anyone see how this set up could be improved or if it's okay at all? Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 20468 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 9167 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31943 |
