Browse Forums What's New Re: Indoor Ceiling Fans 9Aug 17, 2011 1:24 pm Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Indoor Ceiling Fans 18Aug 03, 2015 11:02 am To be totally honest I'm not sure how far away the lights would need to be from the fan to stop the "flashing light" effect. It might even be a total non-issue, it's just something somebody mentioned to me at one point and it has stuck in my mind. I'd say a lighting shop like Beacon would be able to tell you though, they're often really helpful over the phone too Re: Indoor Ceiling Fans 19Aug 03, 2015 12:21 pm thanks for your advise.. googled and found this article.. http://www.charlstonlights.com/blog/tips-on-planning-your-home-interior-with-led-lights Bjhf To be totally honest I'm not sure how far away the lights would need to be from the fan to stop the "flashing light" effect. It might even be a total non-issue, it's just something somebody mentioned to me at one point and it has stuck in my mind. I'd say a lighting shop like Beacon would be able to tell you though, they're often really helpful over the phone too Re: Indoor Ceiling Fans 20Aug 03, 2015 12:43 pm The strobing effect of the lights through the fan depends on the beam angle of the downlights. Narrow angle ones can be reasonably close to the arc, but wide angle needs to be further away. For a 90 degree beam, theoretically, you need to offset from the arc by the same distance as the fan hangs from the ceiling (normally 300mm), but I'd allow a bit more. The problem with the small bedrooms in the plan is that with narrow angle lights, two corners of the room will be fairly dark, and with wide angle lights you'll get strobing. So I'd be inclined to use fans with integrated lights in those rooms, or go to four lower powered downlights. I'd also consider moving the fan in the living space to the left or right, so it's in the middle of a group of four lights, for maximum separation, but that could affect the desired air patterns and visual symmetry. 0 4701 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1665 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 |
