Browse Forums Eco Living Re: Insulated garage door 2Jul 17, 2015 7:27 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Insulated garage door 3Jul 17, 2015 11:09 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Insulated garage door 5Jul 17, 2015 11:09 pm bashworth I do recall seeing insulated garage doors in my local Bunnings store. I actually insulated a standard garage door at my last house as a DIY job using foil board. See this link to find out how http://www.anewhouse.com.au/2015/02/gar ... nsulation/ Thanks Bashworth. I've seen a few DIY products around, but I wish I could find out more information on how effective they are compared with a "proper" insulated door. bpratt You can't really insulate a roller door though, but a sectional or panel lift door you can, and they can already be supplied with insulated panels. If your garage faces north like mine, then get a colour like Surfmist as I did with mine. Thanks Bpratt, and good point. We will also be having a roller door as a "back door" to the garage, so I should definitely do that in Surfmist. Althom Following is a link to a supplier in Perth http://www.insulatedgaragedoors.com.au/ Thanks Althom. Do you have any experience with them? Re: Insulated garage door 6Jul 18, 2015 12:25 pm Just curious as to how heavy the doors are? Years ago timber doors were all the rage..unfortunately the weight of the doors werent always taken into consideration in the garage design, over time this caused all sorts of problem with support tracks fixed to the walls, the vibration resulted in the brickwork continually cracking. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulated garage door 7Jul 18, 2015 12:48 pm No personal experience with them but am looking to replace our existing west facing panel door with one. Currently have 6mm foil insulation fitted to our door but I believe the foam and double skin would be more effective. Good idea to ask re increased mass and effect on mounting to walls etc. I would imagine an upgraded motor would be required. For info the 6mm foil insulation I added increased door mass by just over 2kg. We had our door professionally adjusted for the additional mass. Re: Insulated garage door 8Jul 19, 2015 11:55 am I visited GDI yesterday and the guy there was very helpful. Their motor takes into account the increased weight. Their door is rated at R1.83 and has a thermal break. I forgot to ask about seals. Certainly worth a look into I think. I also went to Eden-Roc but the guy there didn't know what an R-value was and couldn't even tell me the name of their supplier, so that was a waste of time. Next on my hit-list is B&D, as I like their range of colours and finishes. Re: Insulated garage door 9Jul 19, 2015 12:21 pm Seals would enable air conditioning of your garage if it is intended to be used for more than just car storage - small dedicated evap or reverse cycle probably better than hooking it into the rest of the house. Re: Insulated garage door 10Jul 19, 2015 2:45 pm trixee bashworth I do recall seeing insulated garage doors in my local Bunnings store. I actually insulated a standard garage door at my last house as a DIY job using foil board. See this link to find out how http://www.anewhouse.com.au/2015/02/gar ... nsulation/ Thanks Bashworth. I've seen a few DIY products around, but I wish I could find out more information on how effective they are compared with a "proper" insulated door. I can't give you a number but can tell you the difference in comfort levels was huge! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Insulated garage door 12Jul 19, 2015 9:12 pm Althom I'd agree, just fitting the thin foil insulation sheet made a huge difference to our garage. If I remember correctly Bashworth you used foilboard which I'd assume to be even more effective? Yes I used foil board fixed with builders foam so in effect I got around 15mm of insulation across the face of the metal. Where the purpose made doors win over my approach is that with the DIY approach there is just a butt joint between the panels. . . The purpose made doors I saw had a sort of tongue and groove seal between panels. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Insulated garage door 13Apr 21, 2016 11:09 am Heya, We install a lot of garage doors (they are often forgotten). We use thermaboard which we have found is a really good solution. Let us know if you have any questions. Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3275 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6939 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6556 |
