Browse Forums Owner Builder Forum 1 Jul 05, 2015 6:24 am Hi, I thought I would set up this discussion for anybody wondering how much is involved in getting Planning Approval & a Building Permit from you local council. If you need help or require some guidance on this then I have all the info required for generally all councils in Perth. I have just been through the process with City of Armadale _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 3Jul 07, 2015 7:16 am Hi Chalky Not sure what stage you are at in regards to submitting to planning, see below Have you obtained?: BAL Survey Owner Builder licence Soil Test What is needed for Planning Approval Posted & Soft copy 1. Cover letter & checklist outlining what you have enclosed in you application 2. Form 1 downloadable from council website 3. Copy of Certificate of title (land-gate website) 4. Fees payable for estimated construction cost 5. Site plans (1:200 3-4 copies) This includes survey, any retaining proposed 6. Elevations (1:50 or 1:100 3-4 A3 copies) 7. Floor plans (1:50 or 1:100 3- 4 A3 copies) Health Department 1. Effluent design (leach drain or ATU) 2. Fees Technical Services 1. Storm water catchment & disbursement design. (soak-wells rain water tanks etc) 2. Clearing of land or proposed landscape 3. Fees Will you be submitting the dwelling as certified or Un-certified? _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 5Jul 09, 2015 2:48 am Hi dbenz This is who I used..... Green Start Consulting http://www.greenstartconsulting.com.au/ Contact: james@greenstartconsulting.com.au Fast turnaround of plans (2 days) $385 including GST What you will need to supply for certified 1. Full street Address 2. Local Government Area 3. Site Survey 4. Final Working Drawings 5. Specifications (Standard building Specifications Can be purchased from him also $33) 6. Engineering Details/plans (can recommend someone for this) 7. Termite Protection details 8. Energy efficiency (can recommend someone for this) Other Approvals Needed 1. Health department approval (Depending on where you are building ATU or Leach drain approval) 2. Planning Approval Letter/details 3. Contract value of proposed construction (may or may not need this) let me know if you need any more help Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 6Jul 09, 2015 12:56 pm Hi Sparky, We have only created a sketch. What do we do first? Planning approval, then working drawings, then Building permit or is it owner builder license? What is the recommended order of proceedings from sketch please? Re: Owner Building in Perth 7Jul 09, 2015 6:39 pm Hi sparky, Thanks for your help! I will contact Green Start tomorrow Can you recommend someone for: Termite Protection /i suppose we need a quote or description with type of protection that will be used/ Energy efficiency If you are electrician please PM me because i need someone for my project. Cheers Hi chalky 1.First you need Planning approval / i was told you need one if you are requesting variation of R-codes, http://www.planning.wa.gov.au/dop_pub_p ... _Print.pdf i don't have any so i am going for Building Permit / you need owner builder license /permit/ before that http://www.commerce.wa.gov.au/building- ... pplication Re: Owner Building in Perth 9Jul 10, 2015 9:06 am Hi Chalky As Dbenz said you will require scaled drawings before you can submit to planning. These need to be of a standard form a drafty. You will need to obtain a building OB licence before you submit for a building permit. Try to leave this as the last thing you do before you submit to building department as the OB is only valid for 6 months this enables you to attach this with your building permit. To obtain a OB ticket it usually takes about 3-4 weeks. PM for my email address! Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 10Jul 10, 2015 9:14 am Hi Dbenz Can you recommend someone for: Termite Protection /i suppose we need a quote or description with type of protection that will be used/ Unfortunately I can't supply info on this as my project will be concrete and steel and as standards say termite protection is not needed/also James @ green start advised me on this. Energy efficiency Don Fleming Ecorate WA info@ecoratewa.com www.ecoratewa.com (for my project $230) all online and fast 2 day turnaround If you are electrician please PM me because i need someone for my project. Will do! Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 11Jul 10, 2015 9:22 am Chalky If you haven't done so already! Grant @ Entire Fire Management is who I used cheapest and great customer service. You will require a fire management plan from local council for them to do the audit. Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 13Jul 28, 2015 4:10 pm Good to hear chalky _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 15Jul 29, 2015 8:50 am Hi PB relatively all the same, most councils have minimum requirements for planning & building permit applications _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 17Jul 29, 2015 10:14 pm pb if you need anything, please post or pm Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Owner Building in Perth 20Aug 10, 2015 11:22 am Hi chalky, sorry for late reply have Telstra battles, can you pm with your email and I will send them. Cheers _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23863 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4404 |
