Browse Forums Bathrooms and Laundry Re: Hot water control pads 21Jun 11, 2015 12:11 pm Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Hot water control pads 23Jul 07, 2015 7:12 pm ajansen Does anyone just have a whole house controller? (ie. just one for the whole house), it would seem like a pain to me if you have set the temperature (for your shower etc.) and then someone else in the house can just override it by setting a different temperature on another controller. (this is the way the girl at our selections appointment explained how they work) Only one controller can be in charge at any one time. So when in use you cannot change it except from the unit that is in control. And even then, well on the Rinnai at least it can only be changed down, not up. Beside having more is better than having one. As the poster below said if you have one then if the temp is wrong you would have to go to that controller to check. And besides wouldn't get around the issue above anyway as anyone with access to that controller could change it without you knowing. At least if it is near you, you will probably see them. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14415 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20406 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24344 |
