Building a Modified Madison 37.
WiFi can be pretty unreliable and s help of a lot slower. My husband is in IT, while we use WIfi at home he still wants data points for when he wants fast Internet!
Browse Forums Building A New House Re: Who's building with Clarendon?? 9163Jul 06, 2015 8:40 am Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 9165Jul 06, 2015 9:48 am Sydney-build K K For those of you who paid for hills hub box, can you please post it's pic (inside & outside) so I can compare ours. Bit worried that they didn't do ours properly Hills Home Hub 600. Ours is surface mount because the electrical meter box is pretty much right behind it so they could not make it flush. I has asked Duane from Zurcorp to move the Hub furthur up the garage, but he obviously didn't do it. They left it like this inside: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I then made it worse: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Before finally tidying everything up: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Outside is just: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Great work SB!! This is how they did my hub. Also, a quick question - I can't see any telephone line anywhere like yours - did you have to put it yourself or they forgot to put mine in?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ APS Re: Who's building with Clarendon?? 9166Jul 06, 2015 9:48 am Sydney-build K K For those of you who paid for hills hub box, can you please post it's pic (inside & outside) so I can compare ours. Bit worried that they didn't do ours properly Hills Home Hub 600. Ours is surface mount because the electrical meter box is pretty much right behind it so they could not make it flush. I has asked Duane from Zurcorp to move the Hub furthur up the garage, but he obviously didn't do it. They left it like this inside: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I then made it worse: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Before finally tidying everything up: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Outside is just: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Great work SB!! This is how they did my hub. Also, a quick question - I can't see any telephone line anywhere like yours - did you have to put it yourself or they forgot to put mine in?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ APS Re: Who's building with Clarendon?? 9167Jul 06, 2015 10:17 am light487 Wow. Was there a wiring guide? I'm fairly tech savvy.. but that looks complex. How did you know what to buy and what to plug in where? Edit: actually, looking closer it seems fairly straightforward. That red cable on the left going into the NBN modem, I assume it is the one coming through the wall? If not, where does it come from? If we only have 8 data points in the house, can I assume that I only need an 8 port Gigabit switch? Nope, no wiring guide. None of the ports were numbered. I had to persist with Zurcorp and get someone to come to my house and label the numbers. The red cable is the My Air3 data connection, so I can control the air-con via smart phone app. Don't forget you will need an extra port to connect your modem/router to for the internet connection As for what to buy, I only bought the switch myself. Rest was put in by NBN Co and TPG. I just found a spot for each of the items ! Really wanted a small-ish switch but 16 ports. Looking on Whirlpool led me to this slimline Netgear switch. Pricey than the rest, but hey, when space is at a premium, you pay a premium ! leese Why do you need data points?? Can't you just use wi-fi??? Building a Modified Madison 37. Cable >>>>> wi-fi always Re: Who's building with Clarendon?? 9168Jul 06, 2015 10:28 am @APS I dont see a phone cable in your Hub. Mine was done by Zurcorp and it was in my contract. If there was one in your contract, they should have put one in. Call them and get them to come back Re: Who's building with Clarendon?? 9169Jul 06, 2015 10:53 am When you say Zurcorp labelled them, does that mean you know where each cable goes to, for example, port 1 might be going to the master bedroom? I suppose it doesn't really make all that much difference unless there is a fault.. so definitely better knowing than not of course. Yeh.. so I'd need a switch with more ports than there are data points? And if you had 16 data points, you'd need to get a bigger switch? Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 9170Jul 06, 2015 11:23 am light487 When you say Zurcorp labelled them, does that mean you know where each cable goes to, for example, port 1 might be going to the master bedroom? I suppose it doesn't really make all that much difference unless there is a fault.. so definitely better knowing than not of course. Yeh.. so I'd need a switch with more ports than there are data points? And if you had 16 data points, you'd need to get a bigger switch? They didnt label them when they installed them I had to call the office and they admitted the ports should be labelled. So they sent someone out. That wasn't the only issue BTW they had to send someone out. Yeah, if you had 16 ports i the house, you'd need an extra one which connects to the router Re: Who's building with Clarendon?? 9171Jul 06, 2015 11:27 am Cool thanks. Seems like I am understanding. How have you found the experience of a smart wired house? Not just in terms of internet but in the ability to have a media server or even just connected pc somewhere and access the files from it? Good speeds? Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 9172Jul 06, 2015 11:47 am Spart leese Why do you need data points?? Can't you just use wi-fi??? Building a Modified Madison 37. WiFi can be pretty unreliable and s help of a lot slower. My husband is in IT, while we use WIfi at home he still wants data points for when he wants fast Internet! This... WIFI is terrible... Re: Who's building with Clarendon?? 9173Jul 06, 2015 12:03 pm sydney-build, just wondering how fast is the speed of your NBN? Mine got 18Mbps in the morning, but after 10pm, it goes down to 5Mbps ish!!! And this is after we purchase the 50Mbps download speed from Optus! apsterenator, what are all that Foxtel cable for? Re: Who's building with Clarendon?? 9174Jul 06, 2015 2:29 pm WooHoo! My mum has driven past my place twice today whilst she has been out and about doing stuff, and has been texting me some pics to get me excited.... The framework for the slab was about 90% completed last Friday, but today they have started and finished the plumbing, and whilst she was there the second time, the foam pods and steel was all delivered! WooHoo! Slab managers hopes for slab pour tomorrow or Wednesday are looking like a reality! I'm hoping Wednesday though so I can go watch! Building modified Wentworth 33 with a detached granny flat http://nortonbuildingadventure.blogspot.com.au/ Re: Who's building with Clarendon?? 9175Jul 06, 2015 2:39 pm @Sydney-build, do you have a nas setup? I think that's going to be the best solution for me rather than a full blown media server Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Who's building with Clarendon?? 9176Jul 06, 2015 5:43 pm Hi Everyone, How many people got driveway quotes from KMD? And how where they compared to doing driveway after handover? Cheaper or dearer? Thanks Re: Who's building with Clarendon?? 9177Jul 06, 2015 5:45 pm light487 @Sydney-build, do you have a nas setup? I think that's going to be the best solution for me rather than a full blown media server Yes, I have a Synology DS412+ which stores all the kids movies etc. denot sydney-build, just wondering how fast is the speed of your NBN? Mine got 18Mbps in the morning, but after 10pm, it goes down to 5Mbps ish!!! And this is after we purchase the 50Mbps download speed from Optus! apsterenator, what are all that Foxtel cable for? I have the 25/5 plan from TPG and get speeds pretty close most of the time. Re: Who's building with Clarendon?? 9178Jul 06, 2015 5:47 pm Hi Dark Helmet, a driveway guy gave me a rough quote of $100/m2 on your property and $150/m2 on council land. Don't know KMD quote, will let you know on Thursday. Building a Modified Madison 37. Re: Who's building with Clarendon?? 9179Jul 06, 2015 6:01 pm Bricks arrived today..... super happy with the colour. Can't wait till they start to go up... booked to start Thursday.. its forecasted to rain grrrrrrrrr..... We have had gyprock and plastering completed. Cornices going on tomorrow. Exciting times! http://i1282.photobucket.com/albums/a528/jeric19811/bricks%20delivered_zpswe2avvwr.jpg Re: Who's building with Clarendon?? 9180Jul 06, 2015 7:27 pm So jealous/happy for you 1st time! Hopefully the weather clears!! Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6736 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7859 |
