Browse Forums Building A New House Re: Byford Central - M3 Residential - Waiting for Site Works 41May 30, 2015 10:03 am My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Waiting for Site Works 43Jun 08, 2015 3:40 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Site Works Started!! 45Jun 20, 2015 8:31 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Site Works Started!! 46Jun 23, 2015 11:41 am My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Site Works Started!! 47Jun 23, 2015 5:15 pm My Build: viewtopic.php?f=31&t=74866 Byford Central - M3 Residential - Site Works Started!! 48Jun 28, 2015 9:45 am My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Pre Start Completed 49Jun 28, 2015 10:10 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Byford Central - M3 Residential - Site Works Started!! 50Jun 30, 2015 7:55 pm Hey BIMGuy, I have spoken to the developer ages ago and they had it all checked etc, never less I will continue to check while site works are happening! My Build: viewtopic.php?f=31&t=74866 Byford Central - M3 Residential - Site Works Started!! 51Jun 30, 2015 7:56 pm Also - PAD WAS POURED YESTERDAY!!!!!! WWWWWOOOOOOOOHHHOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!! My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential 52Jul 01, 2015 1:10 pm Excited_much Dr House Looking good! I think the only suggestion I have (if it is not too late) is probably to change the direction of your master bedroom door so it is not facing the dining room and living room. Having a door there means people (guests) can look directly into your bedroom unless you have the door closed. Even with the door closed it is still kind of weird to have it there. Hi Im not sure where I would move it to? I dont want to put it in the WIR. And TBH my bedroom is that neat that I wouldn't care who saw in haha Sorry for the late late reply, been away for a while. If its not too late : My suggestion is to shift your WIR to the right to occupy the door space, while the door switch around to be open on the left side of the WIR. That way your public space (dinning and living) won't directly look into your private space. "Occam's Razor. The simplest explanation is almost always somebody screwed up." Re: Byford Central - M3 Residential - Pad Down!!! 53Jul 01, 2015 1:32 pm Yeh to late My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Pad Down!!! 54Jul 11, 2015 8:59 am Photos of the pad Visiting site today, hopefully pad has been loaded up with bricks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Pad Down!!! 55Jul 11, 2015 2:41 pm hi excited_much your slab looks good. mine was poured around last week as well by m3. had an independent inspector inspected the slab. was told by the inspector that my slab poured is of high quality work. so i'm pretty sure yours is too. keep us updated of your progress. enjoy your weekend. Re: Byford Central - M3 Residential - Pad Down!!! 56Jul 11, 2015 6:53 pm i like the style of the wall behind your block. The top strip is a nice change from just finishing off with blocks. Re: Byford Central - M3 Residential - Pad Down!!! 57Jul 11, 2015 6:54 pm woofiekz hi excited_much your slab looks good. so i'm pretty sure yours is too. I thought the same, looks like a great slab Re: Byford Central - M3 Residential - Pad Down!!! 58Jul 11, 2015 6:57 pm Thanks guys, we have had someone look at it and tell us the same - high quality. so great news for all of us!! Where are you building woofiekz? Do you have a thread on here ? My Build: viewtopic.php?f=31&t=74866 Re: Byford Central - M3 Residential - Pad Down!!! 59Jul 11, 2015 7:00 pm Update from today - not much changed but waste water plumbing installed. Water mains tap has been bent/broken off. Some has left a block of retaining wall on our slab. NBN pit was completely covered over with sand. Power dome has been uprighted. Only bad news is that my neighbor is almost at plate height!!!! They only had their bricks sitting on slab last Sunday!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build: viewtopic.php?f=31&t=74866 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11348 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5429 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10248 |
