Browse Forums Bathrooms and Laundry Re: brand new bathroom 4Jul 29, 2006 11:50 pm Geez Jimmy, talk about putting a bloke on the spot!!
Anyway, you've done such a great job with uploading the drawing I at least have to have a go....and here goes. Quote: tiles and tiler labour ..$2000-$2500? Quote: shower screen .....................$1000? Quote: vanity and sink.......... $1000-$2000? Quote: toilet suite............................ .$500? Quote: 800mm x 600mm glass brick panel................... $500? Quote: plumber.......................$2000-$5000? Quote: waterfroofing.........................$1000?(does the plumber do the waterproofing?) Quote: ventilation and lighting including electician labour cost....................$500-$1000? Quote: taps and shower .................. $500? Quote: new wal(2)l and ceiling ......... ....?? What about floor covering? When you take out walls and cut carpet in the middle of the room you need to put smoothedge down and restretch etc. Better add another $300 for that. So, after all that I think your budget is between $15000 and $20000. The actual building work is crucial to get right as far as costs go and obviously sight unseen is pretty difficult but you are actually doing a bit more than renovating one bathroom! Hope this is not too much information but I felt obliged to respond since you had done so much good work!! Good luck with it and feel free to ask more questions. Re: brand new bathroom 5Jul 30, 2006 2:28 am Quote: Geez Jimmy, talk about putting a bloke on the spot!! ..look whos talking builda,im stoked to see ur reply again ur advises been great help,thank again Quote: Anyway, you've done such a great job with uploading the drawing I at least have to have a go....and here goes. im jus so excited bout this project i spend all day/nite on research and design..heres one of my fave as yet *its 2 am * http://i2.photobucket.com/albums/y6/jimmyemce/bath10-1.jpg in the shower i also want a small glass brick window,and i wanna hollow the wall(i suppose pulling out the inner brick 500mmx500mm ? notice my bamboos for fengsui Quote: Presuming this is in the outside wall then how are you going to get it in the wall? Unless you do it yourself (not recomended) then you should allow at least $2000 - $2500.00 for this as you have bricks and timber frame and plaster to consider, plus the cost of the bricks and the frame AND the cost of laying the bricks ...wel,it was suppost to block the toilet from enter/door view,but im going wit a fibro,dunno if this cost me as much tho,should be cheaper Quote: Fine, so long as you don't go frameless in which case you shoud at least double that figure. Quote: Ahh, the fun bit!! Here you have demolition, reframing, plastering, cornice, painting etc. If you allow $320.00 per day per person then you won't be dissapointed. At a rough guess I would say 2 tradespeople x 6 days = $3840.00 plus material. You have some doors and I presume some shelves in the WIR so add another $450.00 for material. Just to be on the safe side I would allow an extra couple of days for two people for the underlay and all the other bits and pieces. *swallows my saliva*..*scratches my head* i've seen those guys on tv put walls up in an hour ! Quote: What about floor covering? When you take out walls and cut carpet in the middle of the room you need to put smoothedge down and restretch etc. Better add another $300 for that. im also planning to change carpet for all bedders..living dinning's tiled Quote: So, after all that I think your budget is between $15000 and $20000. The actual building work is crucial to get right as far as costs go and obviously sight unseen is pretty difficult but you are actually doing a bit more than renovating one bathroom! yep,building works my main concern,is to get it right and because it could be alot costly as i expected like u have suggested and i could well blow my budget..original bathroom is brand new,and the rest of the house renovated,so a new bathroom and unsuite for myself is a dream...btw,i jus bought the property,emty house atm.. Quote: Hope this is not too much information but I felt obliged to respond since you had done so much good work!! Good luck with it and feel free to ask more questions. thanks builda ,its been a privalage ,and always good to listen 2 advises from a forumer let alone a pro tradesman ....and the best part is its FREE .. i wont hesitate to ask for ur proffesion and wil keep u updated on any progress can i also ask wat u do...im assuming .builder? .. where abouts r u? im also assuming Victoria coz of the( brian harris?) sig ..im in sydney btw Re: brand new bathroom 6Jul 30, 2006 10:52 pm Melboure and a registered builder for 20 years doing mostly renovations and extensions.
Believe me there are plenty of traps for the unwary - I know because I've fallen for every one of them at least once!! Thankfully we get the opportunity to learn from our mistakes (fix them!!) and move on but you have to live with them if you make them on your own project! BTW the one hour wall framing/demo jobs is a bit misleading, reality will be quite different by the time everything is prepared, framed and finished. Hope it goes well for you. Re: brand new bathroom 7Oct 18, 2006 8:31 am Hi guys,
Interesting to read your conversation! I too am about to have a bathroom completely pulled out and a new one, including floor installed. So far quotes have been from $22,000 up to as high as $40,000. Considering we are getting everything replaced, new floor and moving the bath and shower to a differnt location in the room is low to mid 20's a reasonable cost? Would I be better off doing the pull out myself and then contracting each of the trades seperately? Thanks. Josh. Re: brand new bathroom 8Oct 22, 2006 1:27 am hi josh, sounds fun (i've demolished my plan). .I think low to mid 20s,u'll get a very decent bathroom.Consider Pulling the old out would save i suppose ...remember to buy good taps, cheap ones wreck easy ,and its a big job to fix
good luck with ur project I am in a difficult situation. Long story short I have been handed over my brand new home in Sydney with everything in the house being great except the windows that were… 0 960 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 5744 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5453 |
