Browse Forums Kitchen Corner Re: indicative price for glass splashback? 9Dec 10, 2008 3:22 pm thanks ed,
I just spoke to a supplier, as we have just finished our flatpack kitchen and DH cant get his head around what happens behind the rangehood. I guess the splashback cant be measured and installed til after the cs benchtops go in anyway. we were just confused about the bit behind the rangehood & price At least now I know we CAN afford it and they CAN customize it to accomodate behind the rangehood Jo Re: indicative price for glass splashback? 10Dec 10, 2008 5:03 pm Hey Zonk, all the above costs are pretty close to the mark for starphire ie $500-$600; our cutouts for the power/phone points are $70 each
Even though we have been given an indicative quote (based on our kitchen plan) the suppliers won't go on-site to measure until everything else in the kitchen is complete - hence they can customise to the millimetre ie. no estimating. We only have a slide-out rangehood so no problem there but we do have a big window which they need to customise around as well as the power points, phone point and rinnai controller so I know where your DH is coming from, lol. 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: indicative price for glass splashback? 11Dec 10, 2008 7:27 pm as far as I know, there's two ways they can do the glass around your rangehood.
one is to cut and install the glass around the rangehood. second is to install rangehood, remove rangehood, measure glass, install glass with the rangehood mounting holes, re-install rangehood over glass. sometimes the second option can be cheaper as there's less cutting involved. Re: indicative price for glass splashback? 12Dec 14, 2008 8:16 pm EcoClassic Everything is customised - why else would you pay $500/m2 for raw material that costs less than $10m2? Ed I'd love to know where you can get 6mm starphire at $10/sq m, last time I checked our price lists it was well above that! Re: indicative price for glass splashback? 13Dec 14, 2008 8:20 pm yes the raw material is cheap. However you have to toughen the glass then also spray it two pac. both these processes are expensive. Plus you need to program a cnc machine to cut out GPO. This makes glass splashback expensive Re: indicative price for glass splashback? 14Dec 14, 2008 8:24 pm borg yes the raw material is cheap. However you have to toughen the glass then also spray it two pac. both these processes are expensive. Plus you need to program a cnc machine to cut out GPO. This makes glass splashback expensive What I am getting at is where can you get 6mm starphire float (the raw material in this instance) for $10 sq/m. I can't even get 6mm CLEAR flot for that price. Must be import stuff.....more waves than bondi beach Re: indicative price for glass splashback? 15Dec 14, 2008 8:32 pm waylow borg yes the raw material is cheap. What I am getting at is where can you get 6mm starphire float (the raw material in this instance) for $10 sq/m. I can't even get 6mm CLEAR flot for that price. Must be import stuff.....more waves than bondi beach I'll bet you a dollar that the stuff you use is imported... about 90% of glass in Australia is imported - from Indonesia, Taiwan and mainly China and India. China has better glass than Pilks (Veridian). They make some of Pilks stuff... Glass is too dear here... I can put you in touch with an importer but you would need the volume to make it economical. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 7051 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35192 |
