Hi All,
Is it normal for a rangehood not to suck the steam in?
The motor works, the light turns on but it does not suck the steam in.
Thanks,
Anton
Browse Forums Kitchen Corner Re: Slide out rangehood problem 7Dec 09, 2008 8:53 pm sorry again, didnt read you guys posts thoroughly. yours is Blanco and if it's front recirculating one then the holes at the front must be blocked. see this link for instructions on the blanco front recirculating slide out rangehood:
http://www.blanco-australia.com/IgnitionSuite/uploads/docs/BRSR60X.pdf Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be… 1 9827 Hi Guys, Those with “box gutter” outside bedroom, how did you stop the dripping water noise? My IP at Melbourne has this problem and it’s very frequent. When the… 0 7945 Will depend if your footings are on piers or not and the soil profile 2 7761 |
