Browse Forums Home Theatre & Automation Re: Projector room set up 6Jun 06, 2015 10:54 pm All depends on size, material, and type (electronic, fixed etc.) Re: Projector room set up 7Jun 06, 2015 11:05 pm This is the place to go for projector screens, it's where I bought mine from. http://www.projectorscreens.com.au/ There are several different screen materials available, including the Acoustically Transparent (AT) screens, where you put your speakers behind the screen, which is what my next screen will be. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Projector room set up 9Jun 06, 2015 11:14 pm A few suggestions: 1. There is nothing like a good projector to give a cinema-like atmosphere at home. - before you build, ideally buy the projector that you want. That way you can plan the best location for the roof mount and a roof power point. - Have your builder or their electricians install a 50mm diameter pipe with draw string from the ceiling location for the projector through to the base of the wall below the screen where your entertainment systems will be setup. Make sure the pipe has large-diameter bends so that is easy to draw cables through. - The reasoning for a 50mm pipe is that cables connectors can be bulky and a 50mm pipe will allow cables to be pulled through relatively easily, although cable lube helps. The pipe also allows cables to be easily replaced if technology changes in the future. 2. Go for in-wall speakers. Much less clutter. Have your walls pre-wired for speakers. 3. I negotiated with my builder to allow my own electricians to go in and do part of the install. 4. A great place to buy the screen and the projector is The Cable Connection. http://www.thecableconnection.com.au. You can also get speakers from them. Make sure your wall frames are deep enough for the in-wall speakers. My screen setup here - cabinet was done by my kitchen installer: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Projector room set up 11Jun 06, 2015 11:22 pm maximus A few suggestions: 1. There is nothing like a good projector to give a cinema-like atmosphere at home. - before you build, ideally buy the projector that you want. That way you can plan the best location for the roof mount and a roof power point. - Have your builder or their electricians install a 50mm diameter pipe with draw string from the ceiling location for the projector through to the base of the wall below the screen where your entertainment systems will be setup. Make sure the pipe has large-diameter bends so that is easy to draw cables through. - The reasoning for a 50mm pipe is that cables connectors can be bulky and a 50mm pipe will allow cables to be pulled through relatively easily, although cable lube helps. The pipe also allows cables to be easily replaced if technology changes in the future. 2. Go for in-wall speakers. Much less clutter. Have your walls pre-wired for speakers. 3. I negotiated with my builder to allow my own electricians to go in and do part of the install. 4. A great place to buy the screen and the projector is The Cable Connection. http://www.thecableconnection.com.au. You can also get speakers from them. Make sure your wall frames are deep enough for the in-wall speakers. My screen setup here - cabinet was done by my kitchen installer: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow nice setup.. how bigs ya screen? I already have external surround setup worth abt 8g... i would love to get in wall speakers but i love the sound of my klipsch/boston acoustics setup. Sound is amazing. I have an old amp.. but still goes hard. 125watts per channel.. bt i have to run optical bcoz no hdmi.. still give good clarity tho considering.. Re: Projector room set up 12Jun 06, 2015 11:30 pm My screen is 100 inch from memory. Either that or 110. My room size is 4.3m long by 3.45m wide. In this room the projector mount is sitting about 3.8m from the front. Make sure you select a projector that has a throw-distance that suits your room. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Projector room set up 13Jun 06, 2015 11:35 pm maximus My screen is 100 inch from memory. Either that or 110. My room size is 4.3m long by 3.45m wide. In this room the projector mount is sitting about 3.8m from the front. Make sure you select a projector that has a throw-distance that suits your room. Yeh sweet. Our room is 3.5 x 3.8m. Daaam so much to think about. Itll be worth it in the end i guess π Re: Projector room set up 14Jun 06, 2015 11:42 pm vijaytee1 maximus My screen is 100 inch from memory. Either that or 110. My room size is 4.3m long by 3.45m wide. In this room the projector mount is sitting about 3.8m from the front. Make sure you select a projector that has a throw-distance that suits your room. Yeh sweet. Our room is 3.5 x 3.8m. Daaam so much to think about. Itll be worth it in the end i guess π If your room is that size, make sure you research projectors carefully. It can be hard to find projectors to suit a room that size yet still throw and image onto a 100inch screen. Your projector will need to be a minimum of 500mm from your room's back wall. Also - extra bracing is needed for the projector mount. The projector can be quite heavy. Get your electricians to install extra timber support in the roof so that bracket can be mounted after plastering is done. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Projector room set up 15Jun 07, 2015 9:04 am Also, you can use this calculator to help figure out your projector throw distance, ideal projector mount location and appropriate screen size. http://www.projectorcentral.com/project ... or-pro.cfm Re: Projector room set up 16Jun 07, 2015 9:55 am maximus - Have your builder or their electricians install a 50mm diameter pipe with draw string from the ceiling location for the projector through to the base of the wall below the screen where your entertainment systems will be setup. Make sure the pipe has large-diameter bends so that is easy to draw cables through. - The reasoning for a 50mm pipe is that cables connectors can be bulky and a 50mm pipe will allow cables to be pulled through relatively easily, although cable lube helps. The pipe also allows cables to be easily replaced if technology changes in the future. A big +1 to that. Some might think 50mm with large radius bends to be overkill, at least until they try to pull come cables through, in particular HDMI cables. Quote: 2. Go for in-wall speakers. Much less clutter. Have your walls pre-wired for speakers. Most people will be happy with in-wall speakers, but if you want better speakers, go for it... just as has been said pre-wire your speakers. Quote: 3. I negotiated with my builder to allow my own electricians to go in and do part of the install. 4. A great place to buy the screen and the projector is The Cable Connection. http://www.thecableconnection.com.au. You can also get speakers from them. Make sure your wall frames are deep enough for the in-wall speakers. +1 to The Cable Connection. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Projector room set up 17Jun 07, 2015 4:36 pm The pipe was a bit of a sore point. The electrician stuffed it up and put 3 tight bends in the 50mm pipe. As such could not get hdmi cables through it successfully. I was not impressed. My workaround was to run cat5 through the pipe and use cat5 to hdmi converters. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Projector room set up 18Jun 07, 2015 9:00 pm maximus The pipe was a bit of a sore point. The electrician stuffed it up and put 3 tight bends in the 50mm pipe. As such could not get hdmi cables through it successfully. I was not impressed. My workaround was to run cat5 through the pipe and use cat5 to hdmi converters. This worries me also, my builder wants to use a 40mm pipe and needs to run up, across the ceiling and back down the wall. I'm worried that it won't work as easily as I want it to to pull cables. Do you think using slim cables like these would've helped you maximus? http://www.scpcat5e.com/hdmi-c-395/hdmi-cables-c-395_114/ultraslim-hdmi-cables-c-395_114_292/ Alkira Homes - The Olivia Re: Projector room set up 19Jun 07, 2015 9:07 pm Possibly. You've still got to get the connectors and cables through without damaging them. After the build was completed I arranged another electrician to install all my wall plates and fit and wire up the speakers. I had this fellow drag the Cat 5 cables through for me. He had to use cable lube. I had 2 cat5 cables run through the pipe. One is for the hdmi converter. The other is a spare. I can envisage that future converters might support 4k with two cat5 runs, if I ever upgrade the projector. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14443 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4830 Hi all, My first post, we are building a house and canβt decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13868 |
