Browse Forums Landscape & Garden Design Re: Preparing clay soil on slope for turf 2May 25, 2015 7:24 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Preparing clay soil on slope for turf 17Jun 05, 2015 12:11 pm Aha. Sandy loam. That is what you are going to need for your turf. You have a bit of a dilemma - you want to prep the soil now but don't want to turf until the ground is warmer. Btw, the ground will take quite a bit of warmer weather to warm up, I would suggest late October rather than September. OK, this is what I would suggest. Firstly, do some planning. Do you really want turf over all that area? Turf is fairly high cost and maintanence. Garden beds, properly established, are not (imo). Also, the land form - you have a pretty constant grade from your building to the verge, now is the time to look at shaping that if you would like a flat area around your house or a swale. (Look at your neighbours across the road.) Being a corner block you could have a couple of metres of flat off that driveway running around the corner, perhaps. Now is also the time to consider any other hardscaping you may want - paths, etc. You should consider a mowing strip between your house and letterbox and the turf, something to run the wheel of your mower on. Makes maintaining a neat lawn edge easier. Could use brick pavers or pour a concrete strip. Aside from that, your soil prep. Issues you have are an unstabilised embankment which will be prone to erosion and weed attack, and your clay soil which you would like to alter. Design and prep your garden beds and complete any hardscaping. You can plant out your garden beds now, use Fu's soil prepping and mulch with say 50 mm pea straw, 50mm tree mulch. Use a sandy loam to say 200mm, discard the excavated clay if you have to. Yes you can and should try to recover as much of the 80/20 as possible, use in the garden beds. Right, to your levels. Ideally, I believe you want the top of your soil in turfed areas to be about 20mm below your paving / mowing strip at turf establishment. That is the soil, not the leaf blade. This will let your paving drain to the lawn and allow for top dressing in the future. (Remember it is far easier to raise a low patch than drop a high one.) You need to then work back from here - go and see your turf rolls, measure how thick they are. Draw a profile of your paving with your clay , then draw the rolls on top, see how it fits. I would work on 200mm of topsoil, including turf, above the clay, so 220mm below paving level is top of clay. Do the earthworks for this. However, this is only at the interface with paving - you can "lose" the excess dirt into the middle of your area if it is not too much and does not create too much mounding. If you are going to reshape the slope then work from your paving edge inwards, establish the 220mm step all the way around first and move the dirt to your fill areas, after recovering and setting aside any topsoil (the 80/20 you can recover). When cutting back soil around your paving and building areas, dont undermine the concrete edge, step off it say 100mm or slope away from the bottom of concrete at a 1 (rise):1.5(run) grade. (You can deal with this dirt later when the turf rolls come in, just box it out then to slot the turf in.) That will leave you with your turf areas. As they are going to be fallow until spring, you need to combat erosion and weed attack over the winter. (Ironically, your turf is what would be doing this job for you.) To slow the velocity of water running over your slope, get it cross ripped or do it by hand. So create a series of trenches across the slope to try to get the water to penetrate. The more the better. "Lose" the spoil from the ripping. Then I would be respreading the topsoil and incorporating as much organic material as you can find cheaply. Grass clippings (same variety as your turf), raked leaves, straw (make sure it doesn't contain seed), anything fine you can mix with your topsoil. Chuck in some gypsum, can't hurt. Just cover over the rip trenches to get a uniform surface. Cover the entire area with a thick layer of tree mulch and walk on it to bind it together. Done. Pull out or spray any weeds over winter. Come spring, bring in your soil ammendments, organic soil and sandy loam (minimium 20% clay, it would be ironic to be built on clay and have non - wetting sand!) to bottom of turf rolls level and lay your turf. Either rake up the remaining tree mulch and re-use on your garden beds or just go straight over the top with your sand if it is thin. Expect your finished levels to drop a little as the organic mater becomes humus and everything compacts a little. Just top dress in very thin layers with 50% sandy loam 50% fine compost to lift it once the lawn has established if need be. My $0.02, hope it helps Re: Preparing clay soil on slope for turf 18Jun 05, 2015 4:54 pm Wow Old Mate , that is some super advice I really appreciate the time you took out to reply. I am reading each section and absorbing and trying to understand it. Will post up my plan forward when I have one. We are kicking off some work tomorrow morning to get gardens going and also a timber retaining wall that will extend the flat area beyond the driveway on the section on the other side of the corner. Will look into possibly extending the corner flat area around the corner as well, as you have suggested. Doing this as exempt development (ie. keeping it under 600mm high and atleast 900mm away from our boundary and other structures). We were going to do a lot of this our self, but I managed to track down a greenkeeper/horticulturalist/aspiring landscaper who was happy to help out for a bit of cash in his spare time Will start up another thread tonight to show our progress. I know how much I LOVE seeing progress photos and before/after photos on this forum, so will try to give some back. I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3063 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3377 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 224296 |
