Browse Forums Building A New House Re: Custom builders vs Project builders 5Jun 02, 2015 10:48 pm We used a small builder that had some designs ready but also did custom designs and apartment developments. Our house has been modified to our block, I have a god friend that builds one-off homes and he said $25k upfront for your documents then about 30-40% more to build. Knowing our budget he suggested to find a builder we like, adjust their closest plan to suit a and spec up the inside. Our block was flat but narrows. In the end I'm happy - I think we got the best of both worlds. Re: Custom builders vs Project builders 6Jun 03, 2015 12:00 am We have a 570 corner block where the long side of the block is where street address is and i havent yet seen any plans from project builders that work with this. I guess i need to weigh up mods to a plan to change entry to the house. Or start from scratch with a custom. Re: Custom builders vs Project builders 7Jun 03, 2015 9:54 am Project homes can be built (depending on the level of finish and design of course ) from $1300-1500 per sq m for the house only excluding site works etc whereas a custom build using a one - off design and small builder will start at $2200 -2500 per sq m and frequently go well north of that. You just have to weigh up how much you can afford as opposed to how much you really want that particular custom design. Stewie Re: Custom builders vs Project builders 8Jun 05, 2015 9:17 pm Where are you looking to build, Anne? We've had one one quote from a custom builder (he builds 1 to 5 homes per year) and it sits around $1200 per sqm. This is based on specs that include 2720 ceilings, higher and lower ceilings in certain areas, high grade insulation, double glazed windows, stone bench tops in kitchen and both bathrooms, 2pac finish to joinery, decorative cornice and so on. Also includes site costs. We're in SA. Re: Custom builders vs Project builders 9Jun 05, 2015 9:27 pm We are building in north brisbane. We have decided to go with 2 storey aswell. So not sure how that affects the per sq metre cost. Obviously the house itself is more expensive because theres more of it. Re: Custom builders vs Project builders 10Jun 06, 2015 4:42 am Peacock Where are you looking to build, Anne? We've had one one quote from a custom builder (he builds 1 to 5 homes per year) and it sits around $1200 per sqm. This is based on specs that include 2720 ceilings, higher and lower ceilings in certain areas, high grade insulation, double glazed windows, stone bench tops in kitchen and both bathrooms, 2pac finish to joinery, decorative cornice and so on. Also includes site costs. We're in SA. Can you share which builder this is? Re: Custom builders vs Project builders 11Jun 06, 2015 7:29 am Stewie D Project homes can be built (depending on the level of finish and design of course ) from $1300-1500 per sq m for the house only excluding site works etc whereas a custom build using a one - off design and small builder will start at $2200 -2500 per sq m and frequently go well north of that. You just have to weigh up how much you can afford as opposed to how much you really want that particular custom design. Stewie What state are you basing these figures on? Re: Custom builders vs Project builders 12Jun 06, 2015 10:32 am NSW predominantly Sydney. Regional prices are generally cheaper as it is for any state. I've seen recent figures quoted in the past where some PH builders can get the price down to around $1000 per sq m but these are very basic, single storey homes. Custom drawn and built homes can end up being much more expensive on a per sqm basis but as I said earlier this depends on your particular site, ease of access, complexity of the design and the level of finish and fittings you are after. I tell all my clients - which are nearly all renos and additions, to allow for around $2500 per sq m as a starting point ( without including window furnishings or floor coverings ) and if they add up all the sq m of their job, they should be in the ballpark cost wise. Final costs in some cases are sometimes north of that as well. Stewie Re: Custom builders vs Project builders 14Jun 07, 2015 9:23 am Consider CMA Homes. They are in North Lakes. We choose Clarendon over them but I would likely go to CMA next time. Build time with project builders is ridiculous for what they do and their rules are insane. Will add that the cost per sq metre is about $1,000-1,200 but not include extra site work, drive and landscaping. Also depends on your choice of finishes you can easily double it. ------------- Building modified Wentworth 35 with Clarendon Homes 13/11/14 Site Cut - 01/12/14 Slab Poured - 02/06/15 Fencing Removed - 16/06/15 Handover Re: Custom builders vs Project builders 15Jun 07, 2015 12:35 pm Will look into CMA, thanks. Its amazing how many builders that are out there that dont come up in a google search. Which is why this forum is so good. Being interstate at the moment makes it hard to find builders etc. Moving at the end of the month, so I cant wait to get up there and start looking properly. We will have about 6months before we can begin building, so plenty of time. Alot of the project builders have plans that we love, but would make some changes and they are either way too expensive to change or they wont change anything at all. I think thats why we would lean towards custom if the price isnt ridiculously higher. Re: Custom builders vs Project builders 16Jun 08, 2015 1:43 pm Someone else to try is Hotondo Homes. I'm pretty sure they are up your way as well. They have quite a large database of plans that they can build from or they will simply build from your own custom designed plan. They seem to be able to keep their costs pretty low too more in keeping with PH prices even though your design may be a one-off. A few people I know have built with them and were pretty happy with the price and quality. Stewie Re: Custom builders vs Project builders 17Jul 13, 2015 9:56 am In some ways custom builders can be cheaper. This can easily be the case when the custom builder designs and builds the home to suit the site rather than just providing a standard house that doesn't quite do the job. It is not a lot of help to say it all depends, but? DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 13307 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 12327 |
