Browse Forums Interior Decorating Lounge Re: Render colour advice 42May 30, 2015 7:19 pm I've used Warm Neutral many times in may applications, its an all round Neutral colour. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Render colour advice 43May 31, 2015 5:16 pm Well I think we have finally decided on Time Capsule. You are right oneJohn it is very similar to Parador Inn, once again the computer screen is so tricky I didn't think I liked this colour but luckily my husband picked up both the sample pots after another trip to the Dulux store. We prefer Time Capsule over the Parador Inn, I guess it is the redness you mentioned that we can see in the difference between the 2. Time capsule seems to be the perfect brown/grey we were after, as much as I love Warm Neutral we decided darker would be better especially for a second storey that gets a lot of sun. Here's a pic of Time Capsule painted on a board, once again the photo is a bit washed out as it does look darker than this, but it still contrasts really well with Woodland Grey and matches the mortar in our bricks really well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Render colour advice 44Jun 29, 2015 12:11 pm Hi Michelle, I wasn't sure how else to contact you but I have seen you can offer some great advice. I have a dilemma - we have chosen Colorbond dune roof, dune front door and garage door. I love the look of dune render but I don't think using dune render when everything is dune is a good idea. Can you suggest a render colour which would go nicely with the above dune parts of the house? My biggest regret is not doing surfmist roof, front and garage door as I love this look, and I we did surf mist I would've done dune render. So now we are looking for options! Please help! Michelle Check this topic out..... Photo of a house with Dune render and Monument on a house. viewtopic.php?f=31&t=48068 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21838 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 8241 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7140 |
