Browse Forums Interior Decorating Lounge Re: Render colour advice 23May 20, 2015 8:19 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Render colour advice 27May 21, 2015 6:35 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Render colour advice 30May 25, 2015 6:22 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Render colour advice 32May 26, 2015 6:03 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Render colour advice 39May 28, 2015 5:10 pm Time Capsule and Parador Inn are very similar. Both are similar darkness to Gnu Tan, but a bit greyer, and a bit more red and less yellow in tint. Time Capsule is very slightly darker than Parador Inn, and slightly further to the yellow direction. I have a feeling the photo you posted is Paperbark render. The house in this post is in Paperbark render: viewtopic.php?p=581867#p581867 Paperbark is close to Self-Destruct. Based on your bricks though, I'd move a little further away from Yellow. That takes you to Warm Neutral and then on to Puppy. This will be quite similar in appearance, but should just match to the bricks a bit better. Based on what you've said in your posts so far, you find colours like Mud Puddle, Gnu Tan to be too dark, so I think the colour you're after is either Warm Neutral or Puppy. Given that you've pained the Warm Neutral and like it, I think it's the safest choice. Re: Render colour advice 40May 28, 2015 9:13 pm oneJohn Time Capsule and Parador Inn are very similar. Both are similar darkness to Gnu Tan, but a bit greyer, and a bit more red and less yellow in tint. Time Capsule is very slightly darker than Parador Inn, and slightly further to the yellow direction. I have a feeling the photo you posted is Paperbark render. The house in this post is in Paperbark render: viewtopic.php?p=581867#p581867 Paperbark is close to Self-Destruct. Based on your bricks though, I'd move a little further away from Yellow. That takes you to Warm Neutral and then on to Puppy. This will be quite similar in appearance, but should just match to the bricks a bit better. Based on what you've said in your posts so far, you find colours like Mud Puddle, Gnu Tan to be too dark, so I think the colour you're after is either Warm Neutral or Puppy. Given that you've pained the Warm Neutral and like it, I think it's the safest choice. Hi oneJohn, Wow thanks you are so knowledgeable with paint colours! First, I need to correct myself now that I looked up your colour suggestions again on my laptop screen and realised the colours were quite different from my phone earlier. Dulux Shattell, Parador Inn and Puppy - not too dark at all. We did like Gnu Tan just felt it was too close to our bricks, it's almost a perfect match, whereas we want a bit of contrast but I don't mind the depth/tone of the colour as such. Yes I still love Warm Neutral but when we were looking at the sample patch in the sun today, my hubby felt it was a bit too light. Hence thinking of going a bit deeper with something else, looking at the Shattell seems quite nice would you compare it to Warm Neutral but darker? Perhaps I should just do WN 1.5 strength? I quite like Parador Inn too. So what is the base of say Shattell and Parador Inn, are they a grey toned brown? Oh and how do you compare Shattell to Clay Dust (that was another thought to darken the Warm Neutral) I'm off Time Capsule now. Which would you think would work best with our bricks and Woodland Grey? Sorry for all the questions We also found a Berger paint, Safari Dust, which is exactly like Warm Neutral less a bit of the pink, painted a sample and it is really nice but still on the light shade, not that I mind too much it will look great in the shade!! Hmmm decisions decisions..... Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 22634 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 8424 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7393 |
