Browse Forums General Discussion 1 May 27, 2015 12:56 pm Hi all, I made a 3 sided pallet shed. It is quite strong etc. except for the front, which wobbles slightly. I currently have a diagonal bracing piece of timber and while that is on, it is extremely solid, but when it's off, at it will need to be so the horses (who the shed is made for) can enter. Any ideas? Re: Wobbly 3 sided shed 3May 27, 2015 3:17 pm I have installed one diagonal bracing wire, but unsure of effect, but I will try the other diagonal to see if that helps. I built it similar to this one, but without any pallets at the front. No cladding yet, but roof on. http://www.goodshomedesign.com/diy-pallet-shed-project/2/ Re: Wobbly 3 sided shed 4May 27, 2015 3:37 pm You will require bracing both diagonals on the roof, and the back wall. Once the cladding is fixed that will also help to stiffen up the structure. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 3361 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 3461 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 2648 |
