Browse Forums General Discussion Re: Scullery or having bigger backyard? Which one worth more 34May 24, 2015 2:40 pm No scullery.. Find it pointless the scullery is at the back of the kitchen. So troublesome if cut stuff at the back and have to bring to the kitchen to cook. Plus the house is too long, so scullery had to go. No display,so we just have to imagine Re: Scullery or having bigger backyard? Which one worth more 35May 24, 2015 3:42 pm How did u make the pantry bigger? Did u put it down the fridge end? I'd be looking at swapping the fridge to the initial single door pantry position and closing off the other end of the kitchen with a walk in pantry. (The end closest to front of the house) Not sure if that is what you have done? Re: Scullery or having bigger backyard? Which one worth more 36May 25, 2015 12:19 pm This is what I would do to the kitchen. I would recess the ceiling so it frames the kitchen off from the rest of the space, i've extended the bench and where the pantry meets the bench in the corner this is a bit of a dead spot but perfect as an appliance cupboard either open or closed off with a sliding door. I've also moved the island bench over a little. Your sink and stove aren't aligned but this doesn't matter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20917 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4211 |
