Browse Forums DIY, Home Maintenance & Repair Re: large tiled balcony leaking to underneath car port 18May 07, 2015 12:12 am ok i am getting some history on this balcony. more is to come hopefully. it seems that it was damaged by a falling gum at some previous time. _reputedly_ it was fixed by insurance to a high standard with new tiles. ummmmm ?? this is so far second hand info. i have asked kind neighbour to get some real details of all work done from previous owner regarding waterproofing or not and extent of work. hopefully the tree damage repair is not the inappropriate white looking grout that is visible. i am prepared to now put money on it that it is. Re: large tiled balcony leaking to underneath car port 20May 27, 2015 10:24 pm HANG ON HANG ON. Everyone's jumping at the idea that the balcony is leaking. The underside of the balcony is lined, remove the lining and look what is in there. I can see a blue down pipe coming out horizontally near the bricks in the second shot. Sounds a lot like roof plumbign issues. I bet you have a red car, causing the rust deposits to appear yellow on it! I bet there is a roof plumbing problem. I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6483 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3282 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4822 |
