Browse Forums Heating, Cooling & Insulation Re: Which wood heater 3May 05, 2015 11:17 am +1 to what Beetaloo said, the you can not have a short flue, it really needs to extend up and above your roof, and get there without having to turn corners. Heat rises, and as it does the smoke rises with it. If the heater isn't hot enough, its not creating that upward movement. That's why you see any heater is a bit smoky until it really gets going (or if the flue is closed off). Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Which wood heater 4Jul 03, 2015 11:02 pm We had our wood heater installed yesterday, we have never owned a wood heater but with it being so cold here and trying to heat the whole house we installed a wood heater to complement the heating. We installed a Regency Alterra on a glass hearth. It has a wood box there but in this pic there I was yet to load it up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Which wood heater 5Jul 06, 2015 12:48 pm Beetaloo One of the reasons for a smoky heater is the flue is too short. I dont understand why length would be an issue? As long as its exiting straight? Or does the length create velocity? Lot927 We installed a Regency Alterra on a glass hearth. Looks fantastic. The glass goes straight on the floor and walls? what does it cost for that option? Re: Which wood heater 6Jul 06, 2015 1:12 pm Quote: I don't understand why length would be an issue? As long as its exiting straight? Or does the length create velocity? The critical dimension is the height above the roof. Ideally the top of the flue should be at least as high as the roof ridge. This is to avoid downdrafts created by areas of high pressure as wind passes over the roof. Re: Which wood heater 7Jul 06, 2015 4:00 pm I agree too Beetaloo. Of similar and connected reasons is where on your roof the flue exits and where your predominant wind comes from. I've seen them only 500mm high on the low end of a roof on the windward side and work very well but I have seen others 1.5m high on the leeward side of a house that have been quite smokey probably for the reason you state above. Stewie Re: Which wood heater 8Jul 07, 2015 12:20 am the glass can be purchased for up to $880 but I would shop around. As for smoke, we have only been fire owners for a few days but very aware of smoke and have been checking outside quite a lot, we are finding that the wood quality we have selected and making sure when new wood goes on it has full air flow for about 20 mins is pretty much giving no smoke - well we can't see it anyway. In fact we have even got a torch out a night to check, we are enjoying the consistent warmth. Re: Which wood heater 9Jul 12, 2015 7:02 am Hi there, I'm looking for a fire also, can't comment on the ones you mentioned. But we had a Ultimate Supreme 24 in the last place it was good but, like with all fires you had to run it hard to start. A nice big piece of redwood would keep the place warm over night. We did have to keep the fire box clear of ash for the best efficiency. Our place had no insulation and cathedral ceilings and was in Adelaide. We are also building a new house and looking for a new fire. We want to use a free standing, higher efficiency slow combustion heater with a fan and ash drawer. Secondary burn rather than catalytic to avoid maintenance, however the Regency Kingston and Richmond appear to have great reviews. I have been looking at the following: Pacific Energy, The Neo 2.5 Pyroclassic IV - although no ash pan Osburn Matrix Our Build Here: viewtopic.php?f=31&t=74037&p=1255246#p1255246 Re: Which wood heater 10Sep 16, 2015 3:36 am Lot927 We had our wood heater installed yesterday, we have never owned a wood heater but with it being so cold here and trying to heat the whole house we installed a wood heater to complement the heating. We installed a Regency Alterra on a glass hearth. It has a wood box there but in this pic there I was yet to load it up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What is under your heater? Is that a piece of special heat proof glass? What is the thickness of this glass? I would say this is a great idea. Re: Which wood heater 11Sep 18, 2015 5:58 pm My dad has a Norseman Nevada and we have been turned off this brand of wood heater. For us, it has been very smoky and we can't get it to burn through the night, no matter how much wood we put in it (we can't get it to shut down low enough to burn slowly). I personally wouldn't buy this brand. Re: Which wood heater 12Apr 17, 2016 2:28 am Heading into winter, thought I'd rekindle this one. Any one got any more input? I'm still thinking of the following, Regency, Kingston Pacific Energy, The Neo 2.5 Osburn, Matrix All high efficiency and long burn times. Our Build Here: viewtopic.php?f=31&t=74037&p=1255246#p1255246 Re: Which wood heater 13Apr 17, 2016 9:22 am I know you discounted the Saxon but We have the rosewood model and if you burn hardwood, once the burn is red hot I find there is no smoke at all. Good luck Our Acreage Build viewtopic.php?f=31&t=82619 Re: Which wood heater 15Sep 01, 2016 7:31 pm Anyone in the market for a wood heater we went into BBQ galore (Hobart store) and they have 20 % off, managed to save $675 off the price of a new Saxon Mahogany, they will even keep it in their warehouse for me until the I am ready for it 0 671 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 4057 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 4257 |
