Browse Forums Building A New House Re: Opinions on brickwork please 2Dec 01, 2008 8:01 pm Hi BB, I can't comment on the brickwork except to say that it doesn't look right to me either.... but where is your sisalation? (the blue or green wrapping paper they put under the bricks - I think its called sisalation?) We couldn't see the inside of our bricks because of this paper. Re: Opinions on brickwork please 3Dec 01, 2008 8:06 pm donuts Hi BB, I can't comment on the brickwork except to say that it doesn't look right to me either.... but where is your sisalation? (the blue or green wrapping paper they put under the bricks - I think its called sisalation?) We couldn't see the inside of our bricks because of this paper. Umm good question, I was half expecting the house to be 'wrapped'. But then I noticed some houses get wrapped, and others don't. Maybe it's a state thing? Is it required in VIC and not NSW? I'll be sure to ask our independent inspector just to be sure. C&G -------------------------------- A new building chapter begins.. Re: Opinions on brickwork please 4Dec 01, 2008 8:09 pm Maybe it is a state thing, I'm sure someone will come along and advise.
We can see the inside of the bricks in our garage, and none of them have not much mortar like that. Sorry not to be re-assuring! Re: Opinions on brickwork please 5Dec 01, 2008 8:15 pm The mortar does look at bit skimpy doesn't it.
heres how ours looked like prior to plaster in the garage at least Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.rentfreeatlast.blogspot.com/ Building in Berwick ----------------------------------------------------------- "Flying is learning how to throw yourself at the ground and miss." - Douglas Adams Re: Opinions on brickwork please 6Dec 01, 2008 8:16 pm Duplicate post for some reason
Deleted the duplicate post http://www.rentfreeatlast.blogspot.com/ Building in Berwick ----------------------------------------------------------- "Flying is learning how to throw yourself at the ground and miss." - Douglas Adams Re: Opinions on brickwork please 7Dec 01, 2008 9:21 pm As I understand it, the wrapping is to create a moisture barrier as well as insulation against heat/cold. As the bricks are porous (can't spell that word), what's going to stop your plaster from getting wet?
Em Re: Opinions on brickwork please 8Dec 02, 2008 12:35 pm Thanks for the replies guys. Apparently our builder never uses sarking for the walls unless it's required as a fire retardant in certain areas. C&G -------------------------------- A new building chapter begins.. I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17296 I wanted to get some thoughts on the quality of workmanship on the following brickwork? are there specific clauses in Australian Standards which relate… 0 4876 |
