Browse Forums Flooring & Floor Covering Re: Flooring without quading around skirting boards 3Apr 16, 2015 4:25 pm Some production builders will do skirtings and kitchen install after floors but there will be an additional cost in doing so (not cheap). Part of the reason for the additional cost is that floors will need to installed early and additional care needs to be taken not to damage the floors for an extended period of time. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Flooring without quading around skirting boards 4Apr 16, 2015 9:16 pm Not sure what you mean by quading, but we in the same dilemma with ours. We going to have the island bench with waterfall edges and we have seen them with Scotia around the outside which IMO looks terrible because it takes away the look from the waterfall edgs. We have spoken with the SS and because the kitchen goes in first then it basically needs something there to hold it down. But he said when the time comes to do the flooring we might be able to come up with an idea. So you might be able to also have a solution with your builder or flooring people. Re: Flooring without quading around skirting boards 5Apr 16, 2015 9:38 pm Quading is the same thing as scotia. I dont think they can silicone the edges as an alternative to scotia with timber floors as the edges need a few mm gap to allow for shrinkage and expansion of the timber. This is the reason for scotia if skirtings are installed prior to flooring. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Flooring without quading around skirting boards 6Apr 17, 2015 12:15 am We are getting flooring after handover but the builder is just going to do skirting but only pin it in place. That way we can pull the skirting off lay the floor then put the skirting in place and fix it there. Absolutely hate quad Re: Flooring without quading around skirting boards 7Apr 17, 2015 11:44 am After looking at ALL the different Timber, Timber Look and composite flooring around.. we realised that most are just a bloody pain in the butt to work with, maintain and generally live with. Some scratch real easy, others you dont want to get too wet or your in trouble and others just make noise when walking over them. The BEST (IMHPO) was the Vinyl Timber Look strips. You can get the builder to install and complete the skirting then the vinyl can be laid straight down. NO glue, NO Quad, NO nothing.. simple, looks as good as any of the other options AND its so so so simple to lift a strip (same size as a timber board) out and replace it if needed. You can lay it yourself its that easy and save lots of $$$ Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 8Apr 17, 2015 1:15 pm The vinyl needs to be laid on a level floor. Most slabs have surface issues and need preparation works. Vinly planks also need expansion gaps on ends as well of about 10mm so it is best to have it laid and then install skirts over the top of the ends to conceal the gaps. Re: Flooring without quading around skirting boards 9Apr 17, 2015 1:18 pm Might be talking about different products. Vinyl doesn't need expansion.. it doesn't expand and its also very accommodating to the floor. only real requirement is that its clean lol Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 10Apr 17, 2015 4:20 pm Roomeat Might be talking about different products. Vinyl doesn't need expansion.. it doesn't expand and its also very accommodating to the floor. only real requirement is that its clean lol My product is Gerflor Creation Clic vinyl floor planks. http://www.gerflor.com.au/products/prof ... -clic.html. Believe me, this product can expand and needs to be gapped at ends and between walls along the length of the plank to prevent lifting if the floor area expands with heat. It is a loose lay commercial product. So I guess it depends on what vinyl product you use. There are lots out there I know. Re: Flooring without quading around skirting boards 11Apr 17, 2015 4:29 pm Yup different product Yours has a clip lock system. Have a look at this.. http://www.integrafloors.com.au/integra ... oCAP3w_wcB Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 12Apr 17, 2015 4:32 pm Armstrong also make a great product. Use to carry lots of this when working for GMK Logistics (Carpet and flooring transport) http://www.armstrong-aust.com.au/resflr ... ments.html Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 13Apr 19, 2015 10:04 am I have just installed 96m2 of serfloor loose lay vinyl planks. They insist there product does not need any expansion gaps, it is 5mm thick with a .7mm wear layer and can be purchased direct from them for $45m2. 30 year residential warranty and a 15 year commercial warranty. I am totally thrilled with the end result and so glad I used these instead of floating floors or carpets. Serfloor tell me there is a guy in Adelaide who supplies and installs their floors for $55m2 which is probably a lot easier than breaking your back doing it yourself. In hindsight i probably wouldn't go to the effort of fitting them myself again for the sake of $10m2. Re: Flooring without quading around skirting boards 14Apr 26, 2015 8:24 am For the OP we are going to use Quickstep 5 in 1 stuff https://youtu.be/6JT17Pvb6k8 We aren't installing Quickstep floors just using the finishing product The other option was this : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Flooring without quading around skirting boards 15Feb 13, 2016 7:27 am I'm thinking of using that border around the kitchen island to yvonneh! Is it expensive? Been looking at quick steps largo and Eligna range...it ain't cheap but looks amazing! There was no pricing for the borders in the catalogue... Re: Flooring without quading around skirting boards 16Feb 13, 2016 8:14 am That border looks great... Will have to ask our quick step supplier if they can supply it fit the island benches Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Flooring without quading around skirting boards 17Mar 30, 2016 2:03 am You should give the builder a sample of floor and underlay your putting down and get him to pass it on to the stone mansions so they can stop the waterfall end short the same thickness of the floor so you can just slide it under the waterfall end when it comes time for the install of the timber flooring and after installation you only need to cork small gaps here and there Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 184 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28319 |
