Browse Forums Building A New House Re: Building on Boundary Problem 8Jun 26, 2007 9:34 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Building on Boundary Problem 10Jun 26, 2007 9:44 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Building on Boundary Problem 12Jun 26, 2007 10:02 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Building on Boundary Problem 15Jun 26, 2007 10:38 pm OK…….now I see the problem!
Yes a bit of a worry! Good luck with your resolve Stewie!!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Building on Boundary Problem 16Jun 27, 2007 8:21 am Stewie from what you've said you won't be paying anything.
The only problem associated with the edge beams is stopping the soil under the neighbours beam from moving. This is generally not a big deal but does take a bit of time to set up boxing etc. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Building on Boundary Problem 17Jun 27, 2007 9:43 pm Cheers Ausdesign for your professional opinion...it's much appreciated and a relief to hear that the problem will not automatically result in extra cost.
I guess I'll have to sit back and wait to hear from the builder to see which direction we head. I'm sure they're doing their best to hurry the process along - after all, the longer they take, the longer it'll take for them to see the $$$. Stewie You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17388 Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will… 0 7047 Hi, I have a block that I am planning on building on soon to both side boundaries, which both have other houses constructed that were also built boundary to… 0 485 |
