Browse Forums General Discussion Re: [NSW] Gregory Hills - Roll Call! 1046Oct 20, 2014 1:54 pm Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: [NSW] Gregory Hills - Roll Call! 1050Oct 25, 2014 8:57 am Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: [NSW] Gregory Hills - Roll Call! 1052Feb 09, 2015 1:20 am 30/01/16 - Site works commenced 02/03/16 - Piering completed 19/03/16 - Slab poured 06/04/16 - Frames completed 15/04/16 - Fascia/gutter/roof rail installed 20/04/16 - Roof tiles completed Re: [NSW] Gregory Hills - Roll Call! 1055Feb 09, 2015 9:40 am 30/01/16 - Site works commenced 02/03/16 - Piering completed 19/03/16 - Slab poured 06/04/16 - Frames completed 15/04/16 - Fascia/gutter/roof rail installed 20/04/16 - Roof tiles completed Re: [NSW] Gregory Hills - Roll Call! 1056Mar 28, 2015 4:59 pm Hey guys, I recently found an article on SMH talking about AGL wanting to start CSG mining in the Gregory Hills area. Is anyone aware of this? You can read the article at: http://m.smh.com.au/environment/agl-sla ... 3w05o.html Re: [NSW] Gregory Hills - Roll Call! 1057Mar 28, 2015 11:32 pm if you read the caption it says AGL had planned currently CSG has been halted in the area Re: [NSW] Gregory Hills - Roll Call! 1058Mar 29, 2015 9:07 pm While the plan may have been halted, AGL seems to have a licence to actually drill in the Gregory Hills area. The reason they stopped was probably due to the drilling only being 500m away from residential areas. I believe they currently need to be a minimum of 2k's away. Anyway, the reason I asked the question was just to find out if people currently living in the area are following this or if it is simply a non-issue? Re: [NSW] Gregory Hills - Roll Call! 1060May 02, 2015 6:02 pm Heidi-Lee Does anyone have a corner block? Interested in what your corner facade treatment is.. Hi, mine is a corner block and the facade treatment is I increased the master's ensuite by 600mm so it sticks out from the side of the house facing the second street. Then I added moroka finish to the side external wall. Not sure if this is good enough as nothing is final until council approves it. How about you? 30/01/16 - Site works commenced 02/03/16 - Piering completed 19/03/16 - Slab poured 06/04/16 - Frames completed 15/04/16 - Fascia/gutter/roof rail installed 20/04/16 - Roof tiles completed Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11039 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3692 In NSW the maximum deposit for building work is 5% until the builder provides HBCF insurance 1 4831 |
