Browse Forums Building Standards; Getting It Right! Re: Roof not built as designed, what do I do? 2Mar 12, 2015 6:54 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 5Mar 15, 2015 7:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 6Mar 16, 2015 9:58 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 9Mar 17, 2015 8:51 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 10Mar 17, 2015 9:20 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 12Mar 17, 2015 10:25 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 14Mar 17, 2015 5:48 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 16Mar 18, 2015 11:33 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 17Mar 18, 2015 12:08 pm StructuralBIMGuy also there are no dimensions on your plans There are definately dimensions. The scale is given in the title block and also in the drawing itself. The section Y-Y is scaled 1:50@A3 and additionally there are dimensions specified which can be scaled off, even if the scale was not given. The section may not have all the dimensions specified but they are easily measured using basic measurement tools scaled off the dimensions given for the ceiling level in the Y-Y section, which also does match 1:50@A3 scaling. There are also dimensions given for the 100mm window mouldings in the elevation drawings which I calibrated from to get the measurements which then match the ground floor plans which do have the dimensions given, so the drawings definately all match up with measurements. I am just still trying to figure out what went wrong so I can attempt to get it rectified. It appears as though the piers are built too wide, especially the middle pier. Re: Roof not built as designed, what do I do? 18Mar 18, 2015 12:21 pm I think the plans says somewhere no scaling, so it's difficult to figure out what went wrong and who's responsible. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 19Mar 18, 2015 12:45 pm Just checked, nowhere does it say anything like 'no scaling' or 'do not scale from these drawings', it does say 'ALL DRAWINGS TO BE READ IN CONJUNCTION WITH ENGINEERS DETAILS' though. Re: Roof not built as designed, what do I do? 20Mar 19, 2015 6:06 am Is building design done by the builder or by your own contractor? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 3008 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 13658 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4448 |
