Browse Forums Building A New House Re: Need to pick your brain about render 2Mar 17, 2015 9:33 am Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Need to pick your brain about render 3Mar 17, 2015 9:38 am Where you are coming from is where you are going to... Re: Need to pick your brain about render 4Mar 17, 2015 11:08 am Roomeat If the brickie stuffed it, I would be making the brickie fix it. If I had a choice between face brick and render I would take face brick any day. Face Brick = character with no maintenance Render = plain boring and forever maintenance. Hi Roomeat. I totally agree with you. We took forever to pick our upgraded face brick and I love love love it. We arranged colours all around this face brick but after 6 weeks going through the dispute process with independent inspectors and council it was just too much and wasn't going anywhere. So we didn't have much choice but to agree with render. Re: Need to pick your brain about render 5Mar 17, 2015 11:19 am onc_artisan ^^ and that too Hmmm good question. Two of my kids have recently had homes built and they also have chips off the corners of the render. I asked why 'corner profiles' aren't used. Apparently they are available but more expensive. WTH? can't be more expensive than having to fix the corner chips. I have rendered a couple of houses as you do..(getting vertical flat is a peicesa....) ...and also acrylic rendered an administration and lab building for BHP at Beenup in WA and that was tough stuff, colour through trowel applied. Pretty sure the impact resistance would be better than conventional sand cement lime render. The acrylic would have less maintenance I'd have thought. Though if you waterproofed 'oxide' coloured render with siloxane as I did(and another 60 or 70 rendered homes), the maintenance is well reduced, it is only when you paint it that maintenance becomes an issue. my 2 bobs worth Thank you onc. I would of thought those corner profiles would be standard as it looks dreadful with all the chips. So yeah that's what it seems to be, my issue is acrylic would be less maintenance but sand & cement looks better. Thanks for your 2 bobs worth You may still have a case, but your next step is to speak to a lawyer. 3 1678 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7998 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18137 |
