Browse Forums Kitchen Corner 1 Mar 03, 2015 9:59 am Re: Question about caeserstone warranty and overhangs - expe 2Mar 03, 2015 10:36 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Question about caeserstone warranty and overhangs - expe 6Mar 14, 2015 12:36 pm Could please you clarify. If the material fails to perform under the recommendations in your design guides are you saying that it won't be covered by warranty because you only warranty the slab prior to installation? I don't think I quite understand. Re: Question about caeserstone warranty and overhangs - expe 7Mar 16, 2015 9:10 am elsie Could please you clarify. If the material fails to perform under the recommendations in your design guides are you saying that it won't be covered by warranty because you only warranty the slab prior to installation? I don't think I quite understand. Our design guidelines are in place to provide installers with the most appropriate fabrication and installation procedures with respect to our surfaces and are completely separate from our warranty terms. Ultimately it is the responsibility of the installer to provide a guarantee of their workmanship and it is at their discretion to adhere to our design guidelines. In saying that, our design guidelines have been created with the intention of giving installers the confidence to be able to guarantee their workmanship with our product so long as the guidelines are followed correctly. Re: Question about caeserstone warranty and overhangs - expe 8Mar 16, 2015 10:15 am That is a good reason for builders to stick to your design guides then. Can I ask what is a good general purpose every day use product for the cleaning of your bench tops in caesarstone and is there a clean and polish routine you can recommend for periodic cleaning? Re: Question about caeserstone warranty and overhangs - expe 9Mar 16, 2015 1:23 pm goody59 That is a good reason for builders to stick to your design guides then. Can I ask what is a good general purpose every day use product for the cleaning of your bench tops in caesarstone and is there a clean and polish routine you can recommend for periodic cleaning? For everyday cleaning we just recommend wiping the surface with a mild detergent and non-scratch sponge. We also offer Everyday Cleaning Wipes and Surface Spray through our online store if you'd prefer. Caesarstone doesn't need polishing, but for an occasional thorough clean we would definitely recommend our Cream Cleanser. It's similar to other products on the market but with a much more gentle abrasive compound which is safe to use on the benchtop. You just apply a small amount to the surface and work it into a thick lather with a non-scratch sponge then give the entire bench a thorough wipe down. Rinse with a sponge and clean water then buff dry with a microfibre towel. I totally agree with everything you have written. Thanks again for your always excellent input and advice. I really enjoy reading your posts cheers Simeon 1 3274 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6137 i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 4716 |
