Browse Forums Building Standards; Getting It Right! Re: Roof not built as designed, what do I do? 2Mar 12, 2015 6:54 am As a builder myself I can tell you that if builder does not follows plans and specifications he has nowhere to go and nowhere to hide, it's a breach of warranty and a a breach of contract. In your case it seems that architectural appearance of your home has been altered without your consent and builder is now saying "too hard to fix tough luck". You are well within your rights to demand that plans be followed however you may need expert help to compel your builder as he may try and ignore and bluff you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 3Mar 14, 2015 11:24 pm enkayz... I 100% agree with building-expert. If they have not built it according to plan then you have the right to have it redone. If your dilemma is as clear cut as it seems from your explanation then your builder would not have a leg to stand on if you lodge a formal complaint with your state's Building Commission. Re: Roof not built as designed, what do I do? 4Mar 14, 2015 11:25 pm building-expert... no posts on your blog this year!?... you must be a very busy man! Re: Roof not built as designed, what do I do? 5Mar 15, 2015 7:10 am tlblhayward building-expert... no posts on your blog this year!?... you must be a very busy man! Yes, too busy and being told to slow down to enjoy what I have, I will be 65 in 3 months (good advice) I have been taking a week off work every month for the last 2 years and soon the plan is to be week on and week off Most likely I was suffering from writers block for blogging but then I have been posting a lot on this forum. I still have a million stories to tell so keep checking Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 6Mar 16, 2015 9:58 am Hi Enkayz Sounds like you are having a bad run with supervision and some of the trades. Please put up the photos, although roofs and gutters are a tough one, and it's often accepted that designers make mistakes and it is something clients can live with, did they have separate details for the front pillar? In the end it often comes down to how much you are aggreived at the out come? As for Structural defects I advise all clients to explore that possibility first. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 7Mar 16, 2015 4:51 pm Here is the ground floor plan showing the roof extents, as well as the section that details how the gutter is meant to be placed, and a picture showing the gutter placement. Thanks for your help guys. I guess my building inspector will help with this on his report? Ground Floor Design Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Section Y-Y Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Result (standing at the bottom of the pillar, looking upwards) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof not built as designed, what do I do? 9Mar 17, 2015 8:51 am Have you checked the dimensions on site but it appears the pier should have been designed wider, I cant see how it's the roof/plumbers fault. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 10Mar 17, 2015 9:20 am Pier to mee looks like its the right size but set out wrongly. The frame would have followed the slab so it is more likely that the frame is OK. Had the pier been forward a little and out to the side a little it would have avoided the problem with the gutter. My bet? Builder will have to do the pier again. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof not built as designed, what do I do? 11Mar 17, 2015 9:45 am Hmm, I hadn't considered that it was the pier setout. They had built the left one in the wrong spot and knocked it down to rebuild it - given that, I assumed the right pier was in the right spot; but you may be on to something. I'll take a measuring tape down and check that 1690 dimension from the middle pier and report back. If that is the case then I guess it will be easier to rectify than rebuilding the roof? There's already a structural support for the roof in that pier, so knocking it down won't be an issue for the roof, if I understand correctly? Re: Roof not built as designed, what do I do? 12Mar 17, 2015 10:25 am The other thing it might be is the roof pitch since the rise is in constant brick coursings measure the eaves and check the drawings ..goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 13Mar 17, 2015 4:44 pm Well, I've measured the piers, the width of them (with render on) is 900. The distance between the outside of them is 1670. I remember that the render is meant to be 50 thick, so I guess that means the brick work was 890 wide with 1690 gaps. I have scaled up the plans in Bluebeam though, and the drawings have the rendered elevations with 890 width: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof not built as designed, what do I do? 14Mar 17, 2015 5:48 pm Measure the distance between your LVL beams on site and check them with detail Y-Y Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 15Mar 18, 2015 11:21 am I don't think I can do that anymore, because the ceiling plaster and electrics are done, so I can't see the beams. I only really noticed this issue recently as I had been concentrated on other things. I have measured the piers themselves though. The right pier (as per section y-y) is 900 X 325, the left pier is 900 x 318. The middle pier is 915x515. The distance between them is 1670. Obviously none of these measurements match the plan, most notably the extra pier depth and width. Re: Roof not built as designed, what do I do? 16Mar 18, 2015 11:33 am It appears the brick pier may not be the problem, in which case it will be the pitching points (off the LVL), also there are no dimensions on your plans... so it will be hard to prove where the mistake ******... goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 17Mar 18, 2015 12:08 pm StructuralBIMGuy also there are no dimensions on your plans There are definately dimensions. The scale is given in the title block and also in the drawing itself. The section Y-Y is scaled 1:50@A3 and additionally there are dimensions specified which can be scaled off, even if the scale was not given. The section may not have all the dimensions specified but they are easily measured using basic measurement tools scaled off the dimensions given for the ceiling level in the Y-Y section, which also does match 1:50@A3 scaling. There are also dimensions given for the 100mm window mouldings in the elevation drawings which I calibrated from to get the measurements which then match the ground floor plans which do have the dimensions given, so the drawings definately all match up with measurements. I am just still trying to figure out what went wrong so I can attempt to get it rectified. It appears as though the piers are built too wide, especially the middle pier. Re: Roof not built as designed, what do I do? 18Mar 18, 2015 12:21 pm I think the plans says somewhere no scaling, so it's difficult to figure out what went wrong and who's responsible. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof not built as designed, what do I do? 19Mar 18, 2015 12:45 pm Just checked, nowhere does it say anything like 'no scaling' or 'do not scale from these drawings', it does say 'ALL DRAWINGS TO BE READ IN CONJUNCTION WITH ENGINEERS DETAILS' though. Re: Roof not built as designed, what do I do? 20Mar 19, 2015 6:06 am Is building design done by the builder or by your own contractor? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 2661 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12815 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4220 |
