Browse Forums Building A New House Re: Building a Santorini 26 in Port Fairy 2Aug 07, 2014 7:18 pm Our Blog: http://werelivingthedream2.tumblr.com Re: Building a Santorini 26 in Port Fairy 4Aug 07, 2014 8:19 pm ~ Anne I used to be indecisive but now I'm not quite sure. Eeek - We're embarking on a knockdown rebuild! Click here for our build thread Our blog: kdrhome.wordpress.com Re: Building a Santorini 26 in Port Fairy 8Aug 22, 2014 8:26 pm My build thread: viewtopic.php?f=31&t=70636&p=1161767#p1161767 Re: Building a Santorini 26 in Port Fairy 13Oct 16, 2014 7:46 pm BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Building a Santorini 26 in Port Fairy 15Nov 07, 2014 6:53 pm BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Building a Santorini 26 in Port Fairy 17Nov 10, 2014 7:52 pm BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Building a Santorini 26 in Port Fairy 19Feb 09, 2015 6:45 am I heard on Friday that having a 22,500l tank means that you have to have more downpipes connected to the tank, and that means a double sealed stormwater system, where everything goes into the tank and only an overflow goes into the stormwater. Can be up to $4k. Smaller tanks don't need it, but I feel it's more sensible to allow for droughts, and to avoid the local water for drinking. That'll mean I hold off on any thoughts of solar power as that would cost $5K plus and not be guaranteed to work efficiently as the house faces north, and you don't have the panels on the front of the house. Planning permit is due Thursday providing no-one protests and that's about a 0% chance, as it's quite a new estate and my place is very much in line with the rest of the street...except for the blockhouse monstrosity with the front roof across the street. Re: Building a Santorini 26 in Port Fairy 20Feb 16, 2015 1:54 pm slugger52 I heard on Friday that having a 22,500l tank means that you have to have more downpipes connected to the tank, and that means a double sealed stormwater system, where everything goes into the tank and only an overflow goes into the stormwater. Just be aware that the overflow discharge capacity needs to be greater than the tank's inflow capacity to prevent overtopping. Very few plumbers know the overflow capacities for the various sizes and types of overflow outlets. You are also talking about a wet system, practically all of the ones installed are sub standard. Common issues are crud build up in the underground pipes and the water retained in the pipes becoming anaerobic. Regularly draining the wet pipes is not very efficient and wastes a lot of water There are some threads in Eco Living that would be worth your while reading. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Well these guys are not looking good... I sent them a written enquiry last week and they have not yet replied. If they cannot respond to a simple… 4 10914 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6602 |
