Hi,
The plasterers have finished some patching in our house and they have done the finishing but putting their top coat product on (a yellowy paint looking product) and sanded it back. Is it ok to paint over this without primer?
Thanks
Browse Forums General Discussion 1 Feb 08, 2015 1:40 pm Hi, The plasterers have finished some patching in our house and they have done the finishing but putting their top coat product on (a yellowy paint looking product) and sanded it back. Is it ok to paint over this without primer? Thanks Re: Can you paint over plaster top coat? 2Feb 08, 2015 3:04 pm You should use a plasterboard sealer ( primer ) first. I've seen painters put about six coats over the top of unprimed gyprock and you could still see where the patch was. Stewie Re: Can you paint over plaster top coat? 4Feb 09, 2015 6:49 pm Yeah..... Priming will make the surface uniform, all cracks and holes that have been patched using a patching compound should be primed after they have been sanded. Only then you should apply paint. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5194 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5386 |
