Browse Forums General Discussion 1 Jul 01, 2012 3:19 pm Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: 7 year old house, slab movement, what sort of fix? 3Aug 27, 2012 8:18 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: 7 year old house, slab movement, what sort of fix? 4Aug 30, 2012 3:23 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: 7 year old house, slab movement, what sort of fix? 7Dec 16, 2014 12:12 pm Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: 7 year old house, slab movement, what sort of fix? 10Dec 30, 2014 1:02 pm Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: 7 year old house, slab movement, what sort of fix? 11Dec 30, 2014 2:39 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: 7 year old house, slab movement, what sort of fix? 12Jan 05, 2015 6:23 pm SaveH2O JimmyL I would be ringing a reputable structural engineer ASAP and getting on top of it. Nothing anyone says on here (no offence) is going to fox the problem. There are a couple of steps that you could also consider doing but No. 1 is a must do. 1. Treat the area around the trees with a soil wetting agent and if the trees are growing in a grassed area, remove the grass and apply a good thick mulch (but not up to the trunk) and regularly water this area. You should also buy a rainwater tank and harvest several downpipes. The tank would then supply gravity fed drip hoses that are under the mulch and coil away from the trees. What would be the appropriate degree for the water moisture to be reached? it might be hard to reach the defined ideal statue. Re: 7 year old house, slab movement, what sort of fix? 13Feb 16, 2015 10:29 am SaveH2O The type of tree, its probable age and the distance from the house should have been mentioned in the opening post! *blush* It didn't occur to me at the time that the tree could be related to the issue. I know so much more now! Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: 7 year old house, slab movement, what sort of fix? 14Feb 16, 2015 12:11 pm Sunpower What would be the appropriate degree for the water moisture to be reached? it might be hard to reach the defined ideal statue. Trees need fairly regular deep watering but if the tree is too close to the house, it will suck the surrounding soil dry by a process known as matric suction. I had assumed that the tree was further away and that watering the tree would lower the matric suction in that area as an interim measure to prevent the situation worsening. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: 7 year old house, slab movement, what sort of fix? 15Feb 16, 2015 12:36 pm dragonchild It didn't occur to me at the time that the tree could be related to the issue. It is a common issue but you are now on top of everything and that is great to hear. You might enjoy the photo below, it looks great but... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6942 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 7045 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10208 |
