Hi thanks for your reply, just trying to get a few ideas on the brick colours before we have to choose early in the new year!!
Thanks again
Browse Forums Building A New House Re: Who else is building with Eden Brae? 11013Jan 04, 2015 11:16 am Granadz ~ Building Drysdale 29+2sq http://jason4rose.blogspot.com.au/ Slab ~ 3 April Frame ~ 17 April Bricks ~ 3 June Lock up ~ 17June Linings ~ 25 June PCI ~ 11 Sept Keys ~ 27 Sept Re: Who else is building with Eden Brae? 11016Jan 05, 2015 3:13 pm We have chosen the same handle - Gainsborough Omni pull with tri lock. It was $500 through EB Re: Who else is building with Eden Brae? 11017Jan 05, 2015 3:40 pm kim_kdr We have chosen the same handle - Gainsborough Omni pull with tri lock. It was $500 through EB Omg!!!!check out this link for the Masters front door handle it is nearly the same they just don't show the pull down handle part probably extra cost!!! https://www.masters.com.au/product/1007 ... handle.jsp Re: Who else is building with Eden Brae? 11018Jan 05, 2015 3:50 pm It's not exactly the same though. I would be interested to see how much the Gainsborough tri lock is at masters. I just googled and at bunnings it is closer to $300. My tender was over a year ago also so the pricing now may have come down with EB. Re: Who else is building with Eden Brae? 11019Jan 05, 2015 4:10 pm Ok, thanks for your help we will look into it just trying to save some $$$. Cheers Building the Sheffield 25 + 2 sq Re: Who else is building with Eden Brae? 11020Jan 05, 2015 4:28 pm Sheffieldhunter, Looking at the handle at Masters, it appears that is only for the handle itself without the lever handle behind it as well as the additional deadlock underneath the big handle. Also, when we got ours we had a choice of a 600 mm long or an upgrade to 750mm for an additional $70 but we are with Clarendon. Ours is back to back pull handles where as some have the tri lock on the inside instead. I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23470 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223809 |
