Browse Forums Building Standards; Getting It Right! Re: New House Brickwork and Mortar Issues (aka Masonry) 27Dec 03, 2014 9:18 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: New House Brickwork and Mortar Issues (aka Masonry) 29Dec 03, 2014 9:42 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: New House Brickwork and Mortar Issues (aka Masonry) 34Dec 30, 2014 1:11 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New House Brickwork and Mortar Issues (aka Masonry) 35Dec 30, 2014 5:10 am Zuccala have helped me out with this problem and I am now satisfied with the house.
Re: New House Brickwork and Mortar Issues (aka Masonry) 36Dec 30, 2014 6:22 am decryption Haven't engaged my own building consultant yet - raising the issue with the supervisor first and will gauge his reaction and response to it. You're right though, the bricklaying is obviously second rate and chances are other things regarding the brick work are below par too. Apart from other obvious issues I don't like split brick under window sill, surely they could have spaced bricks better to avoid this. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog New House Brickwork and Mortar Issues (aka Masonry) 37Dec 30, 2014 7:11 am The sad truth is, that if infact it's found to be defective with those little holes, what do you think their rectification method will be? At a guess id say wipe a little bit of mortar over the hole so you can't see it, which if that hole deepens in the back, will do nothing for the structural integrity of the mortar. Try to see if you can inspect from the back somehow. Supercheap auto had those handheld camera snake things for $100. You could poke a hole in the foil to have a look. I'd also get a screwdriver and scrape those mortar joins to see if it crumbles away. If it does you're in big trouble. Re: New House Brickwork and Mortar Issues (aka Masonry) 38Dec 30, 2014 7:52 am Zuccala have helped me out with this problem and I am now satisfied with the house.
Re: New House Brickwork and Mortar Issues (aka Masonry) 40Dec 30, 2014 9:05 am A pre plaster inspection by a competent private building consultant is one of the most critical inspections. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick… 0 22691 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17321 |
